Fly Posted September 5, 2022 Share Posted September 5, 2022 I plan to machine a hole for my make shift anvil. What is the most common size square hole with hardy holes. I plan to make most of my own tooling, but some I may just buy. I want to keep this the most standard for that reason. Fly Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 5, 2022 Share Posted September 5, 2022 Hardy Hole size seems to be correlated with anvil size; example: I have 3 large anvils with 1.5" hardy holes; however around 1" is the most common size for anvils I have found here in the USA; though 7/8" and 3/4" I have also seen. For my large Fisher with two 1.5" hardy holes I have made a drop in adapter from nesting square tubing that allows me to use 1" hardy tooling in it. Quote Link to comment Share on other sites More sharing options...
anvil Posted September 6, 2022 Share Posted September 6, 2022 What Thomas said. To add a bit. If you buy your hardies from flea markets and antique stores, if they are too big Forge or file\grind them to fit. If too small, add material with any welder and file\grind to fit. Quote Link to comment Share on other sites More sharing options...
Stash Posted September 6, 2022 Share Posted September 6, 2022 A little trick I saw Joey van der Steeg use to easily tighten a loose hardy stem is to wrap it with a bit of duct tape. Sounds like blasphemy but it works a treat taking out some of those annoying little wiggles, and last surprisingly a long time. Steve Quote Link to comment Share on other sites More sharing options...
anvil Posted September 7, 2022 Share Posted September 7, 2022 Lol, he learned that trick from me, if I remember correctly, or at least we talked of it once upon a time. I got a pretty good laugh here when I mentioned it long ago. Saved by the kiddies. Quote Link to comment Share on other sites More sharing options...
Stash Posted September 8, 2022 Share Posted September 8, 2022 Ok Anvil- I will give you the credit as I pass the info forward. Thanks. Steve Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 9, 2022 Share Posted September 9, 2022 I have a couple of pieces of angle iron to shim a hardy hole that doesn't need the sq tubing. Some if very thin; thin sheet metal cut with tin snips. I cut down the bend a bit and then forge the lips out to rest on the anvil---helps keep it from dropping through when inserting the hardy stem. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted September 9, 2022 Share Posted September 9, 2022 A friend of mine showed me a trick to tighten a loose hardy tool. He looped 12ga electric wire in the corners of the hardy hole and that did the trick the copper kinda blended in with the hardy stem. Quote Link to comment Share on other sites More sharing options...
anvil Posted September 9, 2022 Share Posted September 9, 2022 No credit needed. It caught me by surprise in a pleasant way. All knowledge comes from somewhere and I think I read about it in a long ago copy of the Ring. Glad you brought it up. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted September 9, 2022 Share Posted September 9, 2022 I've used a stainless spoon handle to wedge a wiggly hardy stem. Smash down the end of the handle a bit, bend the handle over a little and wedge it in. Easy to remove when done. A butter knife blade could be used for a smaller wedge. Quote Link to comment Share on other sites More sharing options...
Stash Posted September 9, 2022 Share Posted September 9, 2022 I've probably done all of these at one time or another. I've used solder like Iron Dragon used copper I've used wood shim stock or splits of cedar shingles. Copper flashing. Cardboard. Steel wool. Whatever is within arm's reach when I'm looking for a solution. All with varying degrees of success and longevity. Adapt. Improvise. Overcome. Steve Quote Link to comment Share on other sites More sharing options...
bigb Posted November 27, 2022 Share Posted November 27, 2022 I'm planning to make a fullering tool and I am thinking of making the hardie like this so I can drive a wedge to firm it up. I understand some hardie tools you want to be able to install and remove quickly but that would not be the case with a fullering tool. What do you think? (Idea and picture credit to Black Bear Forge) Quote Link to comment Share on other sites More sharing options...
anvil Posted November 30, 2022 Share Posted November 30, 2022 Thats a good way to secure hardy tools and dies. Both the top and bottom dies for my treadle hammer are secured that way. Its actually a pretty quick setup for changing dies. Quote Link to comment Share on other sites More sharing options...
