Fly Posted August 19, 2022 Share Posted August 19, 2022 New guy having hard time posting so this is a test. Fly Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 19, 2022 Share Posted August 19, 2022 Coming in clear here. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 19, 2022 Share Posted August 19, 2022 You made it into "Solid Fuel Forges" OK. The Read This First Thread will help with getting the best out of IFI. Quote Link to comment Share on other sites More sharing options...
Fly Posted August 19, 2022 Author Share Posted August 19, 2022 Well I think maybe I tried using my smileys maybe was the problem. Any way I,m thinking about making a trench charcoal forge for my first one. I will make a gas forge in the future but this with get me started on learning this craft. My thoughts on a trench forge was using lump home made charcoal & maybe just wood at times. I live in a hard wood forest in eastern okla and have a charcoal retort. My thoughts are welding a steel frame & mounting fire bricks on a 45 or 30 degree angle with a Pipe air supply with drilled holes as a gate valve air control. What are your thoughts to my plan? Fly Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 19, 2022 Share Posted August 19, 2022 (edited) I would consider a side blast forge for Charcoal. Might look through the JABOD thread for more ideas. https://www.iforgeiron.com/topic/52623-anatomy-and-a-brief-history-of-simple-side-blast-forges/ https://www.iforgeiron.com/forum/267-jabod-just-a-box-of-dirt/ I started a side blast a while ago but life has gotten in the way of finishing it. I really need to get going on it again by lining it with clay. Wow hard to believe it's been 4 years since I made it this far. Edited August 19, 2022 by Irondragon ForgeClay Works add picture Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 19, 2022 Share Posted August 19, 2022 I hear the wind singing . . . JABOD! (Just A Box Of Dirt) No need to get fancy, a box of dirt is easy to make and change as you're skills grow and you learn what you need and want in a forge. Building a masonry forge for your first will lock you into something that might not work for you. SCRATCH what I just deleted, Randy's links are much better threads. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted August 19, 2022 Share Posted August 19, 2022 Tho I use red brick and hard fire brick to augment my side blasts and JBODS, I have a habit of melting them. building a permanent forge, using brick for the hearth is fine but not the fire pot. It’s easy to build one out of steel plate, but traditionally it was a box filled with fly ash and clinker. Quote Link to comment Share on other sites More sharing options...
