Jobtiel1 Posted August 15, 2022 Share Posted August 15, 2022 Hi all, I like making axes, and I want to practice forge welding further, so I'm looking at making a socket axe most produced in scandinavia. something akin to this: Do you have any idea on what the starting thickness of the material would be best suited for something like this, I have some 8 mm (.3 inches) flat bar which is wide enough to get the starting pattern out, but I'm not sure if the thickness is sufficient. Do any of you have experience with these kinds of axes? Thanks. ~Jobtiel Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted August 15, 2022 Share Posted August 15, 2022 no clue your linking rather than just posting failed, there is no photo Quote Link to comment Share on other sites More sharing options...
Jobtiel1 Posted August 15, 2022 Author Share Posted August 15, 2022 Hi Steve, I changed the picture, it should be good now. ~Jobtiel Quote Link to comment Share on other sites More sharing options...
Latticino Posted August 15, 2022 Share Posted August 15, 2022 I believe that James Austin has been experimenting with forging these axes for a while. If I remember correctly he has a visual storyboard online somewhere that goes through the process. Hopefully you already have experience forging axes and forge welding, as this is by no means an easy project. Quote Link to comment Share on other sites More sharing options...
Jobtiel1 Posted August 15, 2022 Author Share Posted August 15, 2022 I have experience forging and forge welding axes, but it's not like I'm an expert. I'll have to look that up and see if there are mentions of preferred stock sizes, thanks! I want to see if I can get the forge welds, I have been nailing them pretty consistently lately and have done quite some good welds on projects, I guess this is just to see how far along I am with forge welding as I want to get good at it. plus the axe looks really nice so I'd be happy to own one that I made. ~Jobtiel Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 15, 2022 Share Posted August 15, 2022 If you will be forge welding it, you don't want to start with overly thick stock like you might do with punching and drifting an eye. Thickest I would use is a bit over 1/2 the thickness at the thickest solid spot right in front of the eye. The poll will be another forge welded piece. Quote Link to comment Share on other sites More sharing options...
Latticino Posted August 15, 2022 Share Posted August 15, 2022 Check James Austin's Blog: http://forgedaxes.com/blog/ and don't miss out on the links. He doesn't specifically note the stock he uses, but the details on the process are invaluable. Note that James is a world class traditional axe forger, and even he indicates that this is a difficult project. Also, he usually works with a team of, at minimum, a striker and director... Quote Link to comment Share on other sites More sharing options...
Jobtiel1 Posted August 15, 2022 Author Share Posted August 15, 2022 I'll just try it, worst that can happen is wasting fuel, and then I would know what I need to practice before a second attempt. Thanks for the links anyway I'll study them for some pointers. ~Jobtiel Quote Link to comment Share on other sites More sharing options...
