TWISTEDWILLOW Posted August 14, 2022 Share Posted August 14, 2022 Ive made some rolled roses but I haven’t played with the stacked ones yet an I thought about ordering some blanks to try em out, I watched some videos on making them an I saw him using a ball end punch to do some shaping, then I started in on watching a jingle bell video and he was using different sizes of ball end punches for that too, so i figured I’d make a set of em in different sizes, I found some ball bearings in the different sizes I wanted online, 2” ,1-1/2” , and 1-1/4” I saw some that were carbon steel, there was also some chrome ones and stainless ones, I figure chrome isn’t a good idea for safety reasons so that’s out, So that leaves stainless an carbon, i was thinking of ordering the carbon ones and planned to weld a piece of 3/4” sucker rod to them for a handle Is there any reason why this wouldn’t work or it’s a bad idea? also I saw were someone was using the round end of a carriage bolt to do the same thing but I can’t imagine that wolf last very long, Quote Link to comment Share on other sites More sharing options...
anvil Posted August 14, 2022 Share Posted August 14, 2022 A bottom tool helps as well. It can be made from iron, or simply the end grain of a wood stump. I've used an aspen log for decades. I made a set of bottom tools out of different sized seamless black pipe. I rolled the top edge outward and welded a crossbar on the bottom to clamp in my post vice. My sizes are from half inch to 8". I call them a poor man's dapping block. The type of steel isnt critical because you are hammering hot iron into a hollow space. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 14, 2022 Author Share Posted August 14, 2022 That was my idea for the bottom tooling on the sleigh bells I wanna make, is use a pipe, I have a beat up ol swage block but I don’t have a lot of different hole sizes on it so I figured pipe would be cheap an easy Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 14, 2022 Share Posted August 14, 2022 For the smaller dishes I like to use lifting eyes, larger dishes bottom of welding tanks that are NOT Acetylene tanks!!!!!!! Quote Link to comment Share on other sites More sharing options...
BillyBones Posted August 14, 2022 Share Posted August 14, 2022 TW, i bought my ball punches from Harbor Freight, called a doming block set i think. They came in a set from 1/16" up to 1". They are short so something to hold them with is needed. They have held up well for what i use them for. I have also repurosed a couple of them. The steel is pretty decent for as cheap as they are. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 14, 2022 Author Share Posted August 14, 2022 Thanks BillyBones! I’ll check those out too! Sounds like they might come in handy for some smaller projects! Quote Link to comment Share on other sites More sharing options...
anvil Posted August 15, 2022 Share Posted August 15, 2022 Heres some pics One of my small ones and one of my big ones. I prefer, tho not always, to sink into a form than over a stake. These actually work as both. For say a drip pan, you can sink it to please, then roll the outside edges around the top of the die.Both have their place. Use a top tool to fit the job. The size of the bottom tool just determines the chord, not its final shape. For instance, in my large one I have used my cross peen to get flat surfaces within a rounded top. The good thing about rust in a blacksmith shop is it goes away with the first reuse. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 16, 2022 Author Share Posted August 16, 2022 Anvil, Those look really handy! Thanks for sharing pictures! Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 16, 2022 Share Posted August 16, 2022 Heavy ring bolts also make good bottom tools. Here are a couple I made for my fly press (upper right): The larger one is welded onto a piece of 1/2” plate that already had a 3” hole in it, and the smaller one rests on the bigger one, with the short pipe registering it in place. I use both with the tool on the lower left, which started life as a trailer hitch ball. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 16, 2022 Author Share Posted August 16, 2022 That’s pretty slick lookin John! I dug around an found a big ball bearing my dad gave me decades ago that came outta a blown up tank, The sucker rod looked like it might be to big for a handle an might get in the way if I’m trying to work the inside of a sleigh bell, so I dug around the scrap pile and found a small old four way lug wrench, I think I’m gonna cut a handle off of it an weld it to the ball bearing and try that out before ordering ball bearings online cause they were pretty steep Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 16, 2022 Share Posted August 16, 2022 Or try forging down the mouth of the wrench, welding it shut, and grinding it round. (Hm...I just cut up a lug wrench; I should give that a try myself....) Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 16, 2022 Author Share Posted August 16, 2022 That’s an interesting idea, I might try that with one of the other sides just for fun Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 21, 2022 Share Posted August 21, 2022 Per a request; here are some of my dishing forms and a couple of my dishing hammers. Please feel free to ask specifics about any of them. All were sourced on the cheap, many modified from other use items; some just weird. (Like the lens grinding cups for making eyeglass lenses...) Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 25, 2022 Author Share Posted August 25, 2022 Thanks Thomas! That’s quite the collection! I’ll definitely start keeping my eye out for lifting eyes, I just got in some ball bearings, 1-1/4” 1-1/2” and 2” to make my ball end punches Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 26, 2022 Share Posted August 26, 2022 Love the reflection in the large ball. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 26, 2022 Author Share Posted August 26, 2022 yeah I saw that too when I was in my messy shop, so I moved outside to the smithy to take the picture, figured y’all would rather see a tree in the background then five million different colors of weed eaters lol Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 26, 2022 Share Posted August 26, 2022 Maybe shine the others up next time. It might be the best way to make a wall full of old weed eaters look good. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 26, 2022 Share Posted August 26, 2022 The way to get them to look good is to trade them back to their owners for steel engravings of dead Presidents or Ben Franklin.... Quote Link to comment Share on other sites More sharing options...
Scott NC Posted August 26, 2022 Share Posted August 26, 2022 Those are stress balls. You are supposed to roll them around in your hand to get rid of anxiety. It kind of worked for Lieutenant Commander Queeg. Kind of. Seriously, it will be fun to watch you put them to work. I remember the cannonball agitators... Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 26, 2022 Author Share Posted August 26, 2022 2 hours ago, ThomasPowers said: The way to get them to look good is to trade them back to their owners for steel engravings of dead Presidents or Ben Franklin.... That’s what I do! They bring ‘em to me an I trade their weedeaters back to them for money! Scott, don’t get me started! Lol Quote Link to comment Share on other sites More sharing options...
anvil Posted August 29, 2022 Share Posted August 29, 2022 Lol, I used to say that alchemists tried to turn lead into gold and Blacksmiths do turn iron into gold. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted September 2, 2022 Author Share Posted September 2, 2022 I don’t make money of blacksmithing it’s just a hobby but I could see turning steel into money! Quote Link to comment Share on other sites More sharing options...
JHCC Posted September 2, 2022 Share Posted September 2, 2022 I'm just happy when I make enough from commissions to offset the costs of what could easily get to be a very expensive hobby! Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted September 12, 2022 Author Share Posted September 12, 2022 I just now got around to welding up my new punches, 2”, 1-1/2” , 1-1/4” All three I went ahead and used 3/4” sucker rod cut to 6” Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted September 14, 2022 Share Posted September 14, 2022 A long time ago Debi made this ball punch to use with a treadle hammer, power hammer or hand hammer. A 1 inch ball bearing. Billy has already seen this but for everyone else enjoy. Quote Link to comment Share on other sites More sharing options...
