natkova Posted July 3 Share Posted July 3 Here is how I build it I hope it's not too close to forge . Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted July 3 Share Posted July 3 Looks good to me! I have one of my post vises that close to my forge, I don’t think you’ll run into trouble Quote Link to comment Share on other sites More sharing options...
natkova Posted July 3 Author Share Posted July 3 Thanks for advice , well i had it mounted on stump. issue was i wasnt able to even twist stuff in it now its have enaugh wideness. I had to make it a litle bit out of shape becasue doors i was walking in and it will get in way so it is like trapezoid shape because i had to save some space. One question is it safe to weld stuff in vise? I welded one threaded rod i needed it more lenght so i welded both threads. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted July 4 Share Posted July 4 Should be OK as long as you don't weld stuff to the vise. Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 10 Share Posted July 10 Ground to the stationary jaw as close to the work as possible or to the work itself. You do not want the current passing through the screw and screw box threads, it buggers them up. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted July 11 Share Posted July 11 I always ground to the work Quote Link to comment Share on other sites More sharing options...
