ChrisL Posted June 27, 2022 Share Posted June 27, 2022 Hi, I'm forging a cooking tripod and I need to find a way of suspending the fire plate from the legs. I saw these silver things. Does anyone know whet they are called and where I could get some. Thanks :-) Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted June 27, 2022 Share Posted June 27, 2022 I don’t know what it’s called but you can get oddball cast iron an cast steel fittings from several big steel suppliers, I think I saw something like that when I was looking for cast steel balls last winter, I can’t remember the name of the company but it was down in Texas and they had all kinds of odds and ends, I’ll see if I can find the invoice an find the name of the company, Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 27, 2022 Share Posted June 27, 2022 If the mount point will be stable in location and you adjust height with the chain; why not forge a loop or drift a hole in the leg? (Or rivet a hook on...) Link to comment Share on other sites More sharing options...
Les L Posted June 27, 2022 Share Posted June 27, 2022 You can wrap the top section of your hanger around the leg 3-4 times and it will do the same thing as the extra piece. Slide it to the desired height and the weight will lock it in place Link to comment Share on other sites More sharing options...
ChrisL Posted June 30, 2022 Author Share Posted June 30, 2022 On 6/27/2022 at 1:39 PM, TWISTEDWILLOW said: I don’t know what it’s called but you can get oddball cast iron an cast steel fittings from several big steel suppliers, I think I saw something like that when I was looking for cast steel balls last winter, I can’t remember the name of the company but it was down in Texas and they had all kinds of odds and ends, I’ll see if I can find the invoice an find the name of the company, Thanks Twistedwillow thats really kind of you. On 6/27/2022 at 5:12 PM, ThomasPowers said: If the mount point will be stable in location and you adjust height with the chain; why not forge a loop or drift a hole in the leg? (Or rivet a hook on...) Thats a good idea I will look into that. Link to comment Share on other sites More sharing options...
Please sign in to comment
