ASA_Walrus Posted May 12, 2022 Share Posted May 12, 2022 Hello all! I got lucky this week and grabbed an old post vise, and after a little wire wheel work, and some oil it’s back to moving condition, only issue I’ve had is that when turning the vise, the screw box spins independently with the handle when closed all the way, so significant force can’t be applied without holding the screw box body. The threads look great, it feels like there should be something either keying the screw box to prevent spinning, or adding friction against the vise body for the same purpose. I can post more pictures later today, but the construction of the screw box looks neat, like a roll of steel was forge welded into a circle, and then the threads bored out, and the washers on the handle side show similar construction, forge welded rings which is cool to see. Before and After Pics + Markings Attached Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 12, 2022 Share Posted May 12, 2022 Yes, the screw box should be keyed into the heal (non moving) jaw. I don't know how on your vise, methods vary. Nice vise, looks better than either of mine. Mine work though. Seriously, that's a SWEET score. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 12, 2022 Share Posted May 12, 2022 Like Frosty said the screw box should have a tab (key) that fits into a slot on the stationary leg. If the key is missing not hard to weld on a new one and fit it to the slot. Quote Link to comment Share on other sites More sharing options...
ASA_Walrus Posted May 12, 2022 Author Share Posted May 12, 2022 Yeah, unfortunately no key, and there’s not really a key slot on be vise either, here’s a some more pics; First few are angles of the screw box, second set are one of each leg of the vise. The only solution I see is fitting a narrow “L shaped piece of metal into each of the two holes, with the screw box oriented such that they’re vertical, so rotation would be blocked. Though I likely lack the skill to make those haha. Quote Link to comment Share on other sites More sharing options...
NoGoodWithUsernames Posted May 12, 2022 Share Posted May 12, 2022 A key welded on the outside of the screw box should suffice, mine does not have a keyway in the vise but has that same shape and it keeps the screw box from turning, might turn a smidge either way as I tighten or loosen before the key hits the vise but not much. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 13, 2022 Share Posted May 13, 2022 I was thinking of suggesting welding on a nub to catch it from spinning. Then I was thinking some threads are brazed in so that might loosen the threads if that were the case. The screw box needs to move with the screw up and down so you don't want to weld it to the jaw opening for it. I'd suggest minimizing the heat transfer if you weld on nubs to catch the oval preventing spin. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 13, 2022 Share Posted May 13, 2022 In the next to last picture I think 2 round pins ground to fit snug in the indents will keep it from turning, no welding needed because the stationary leg has an indent top & bottom that would stop the pins from falling out. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 13, 2022 Share Posted May 13, 2022 That's a good idea Irondragon. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 13, 2022 Share Posted May 13, 2022 WARNING that is an "old school" screw box made by forge brazing parts together---the screw threads are probably forge brazed into that tube that was forged from flat sheet---see the seam? I would not do anything that used heat on the screw box!!! As for the vise body, not hard to cut a keyway in it... Quote Link to comment Share on other sites More sharing options...
