ede Posted January 17 Share Posted January 17 I just purchased a 100lb LP tank to be used for dual purpose: Treadle torch with gas saver. Acetylene was too expensive and I found out that I was using too small of a recommended cylinder per Smith's recommendation of: "Acetylene must not be withdrawn at more than 1/7 of the cylinder capacity per hour (50 SCFH for a 350-cu.-ft. cylinder)." Get back to running my propane forge until I finish repairing my masonry forge, plus, the extra heat in the winter. I have used a t-grade hose in the past and want to switch to something a little more protected and do a run of 20 feet to the LP rated gas saver for the treadle and then a flexible line to the torch. Should I do a copper line to the gas saver, then t grade welding leads? I also will be adding a Y connector to do a separate line to the gas forge. In the past I have used a red t-grade hose and I've notices some stress cracks by the regulator. I want to switch to something that is sheathed and do a run of at least 20 feet, any recommendations? I've actually burned through a propane tank hose that goes to a 1 lb disposable tank connected to a benzomatic. Finally, the torch tip on an acetylene tip is not supposed to be used with Propane apparently, correct? I wasn't sure where to post this since I'm asking gas forge questions and torch questions, all related to an LP tank, apologies to the moderators. Quote Link to comment Share on other sites More sharing options...
JHCC Posted January 17 Share Posted January 17 I only have a good answer to the last question, which is Yes, acetylene tips are no good for propane. I see that your gas saver is propane-rated; make sure your regulator is as well. Having built my own treadle torch, I’ll be interested to see how yours goes. Keep us posted. Quote Link to comment Share on other sites More sharing options...
