angiolino Posted October 25, 2021 Share Posted October 25, 2021 Point Carry-All Fork Attachment hello sorry if I disturb, could you kindly suggest me how to build a self-loading rear bucket fork for this old fiat tractor, in my part it is called the pruning fork, as you call it. how do I make it to be light and sturdy? Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 25, 2021 Share Posted October 25, 2021 Good to see you post Angiolino. The bottom picture shows everything you need to make one for your tractor. The only tricky thing would be the fork tines themselves. The weight you want to be able to lift with it will determine what you need to make them strong enough. Everything in the picture is pretty self explanatory, what do you need to know? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted October 25, 2021 Share Posted October 25, 2021 Around here we call them bale spears or bale spikes. The one in the bottom picture is the most versatile, allowing the spikes to be moved back & forth. Quote Link to comment Share on other sites More sharing options...
angiolino Posted October 26, 2021 Author Share Posted October 26, 2021 I should use the right materials to make it strong strong but light at the same time, I am afraid that the fixing supports are not adequate enough. Thank you. Quote Link to comment Share on other sites More sharing options...
