Trees Posted September 30, 2021 Share Posted September 30, 2021 Interested to hear people's experience applying Plistix... I was putting my first coat on the kiln shelf pieces that will be my forge doors and the K26 firebrick piece that will be the removable divider. I stirred the powder well with the water to maybe slightly thinner than latex paint to start and used a paintbrush. On the first brush strokes it would clump massively - like it was instantly drying and clotting together, leaving the areas between the clumps with barely any Plistix on them. Was similar for both the kiln shelf (high alumina I believe) and the firebrick, but a little worse on the brick. I tried 'buttering' a couple pieces of the kiln shelf first - not drenching but spraying quite a bit of water on it, but that maybe seemed to make it worse? Also tried mixing thinner and thicker with no improvement. The picture was taken after spending a bunch of time smudging out the worst of the clumps. Is that just how it goes with the first coat, or is there something wrong with my technique? Also - I've noticed that once the remaining mixed Plistix dries a bit in the container, it seems revivable by mixing in more water. Wondering if I put a lid on the container, if the same leftover mix could be used in a day or two if a bit more water is added again? Link to comment Share on other sites More sharing options...
Trees Posted September 30, 2021 Author Share Posted September 30, 2021 And now to piggyback on this post - after the first real heat of the Kast-o-lite in the forge body, I've noticed some of the dreaded cracks appeared. I was heating up the forge to finish burning off the stinkies in the cured KOL before applying 2 coats of Plistix to the whole inside. Am I correct that these cracks can be effectively patched with the Plistix, or should I be trying to get a bit more Kast-o-lite in there first for added strength? Link to comment Share on other sites More sharing options...
Please sign in to comment
