Dessertdingo153 Posted August 12, 2021 Share Posted August 12, 2021 Wondering as most crucible tongs are quite expensive. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 12, 2021 Share Posted August 12, 2021 No... you run a serious risk of breaking the crucible and doing harm to yourself and any others around or starting a very bad fire. Tongs are not hard to make. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 12, 2021 Share Posted August 12, 2021 Proper tongs are a lot cheaper than medical bills. Also, welcome to IFI! Quote Link to comment Share on other sites More sharing options...
Purple Bullet Posted August 12, 2021 Share Posted August 12, 2021 If you are thinking of using pliers, you must be talking about small crucibles. I don't know how your furnace is set up (top access or side, like most forges) but you may be able to make your own tongs. Crucible tongs should SUPPORT the crucible, not grab it. You might start with an old pair of pliers and weld curved pieces of flat bar to the jaws that will fit mostly around the crucible, but will meet near the hinge before applying any pressure to the crucible. That said, if you aren't SURE of your skills to build something like that, listen to JHCC. Even with all protective gear, molten metal can be dangerous. Quote Link to comment Share on other sites More sharing options...
11xray Posted August 20, 2021 Share Posted August 20, 2021 Check out this video, with basic tools you can make a set of tongs. Same set I've been using since I started, and they've not let me down. I have progressed from bolted to welded, added some steel bar for extended handles, other than that mine are exactly as the video shows. The video gives very good instructions for creating the tools. Quote Link to comment Share on other sites More sharing options...
