jrmysell Posted July 27, 2021 Share Posted July 27, 2021 I'm wanting to eventually make some hammers and I'm by myself most times so no striker and no power hammer. So I'm making a guillotine tool for bottom and top fullers for the necks. Most of what I read/watched says don't use mild for that as they'll eventually bend/mushroom too much. S7 and H13 are recommended quite a bit for those type of tools from what I've read on here with H13 seeming to be slightly preferred. My issue is finding H13 flat bar where I don't have to pay triple digits. Hudson Tool has it at a decent price but apparently they have a min of $250 for flat stock now. I can find round much cheaper, but obviously I'll need it in flat for dies for my guillotine tool. So now to my actual question. If I buy 1.5" round in H13 would that be too much to hand forge down to 1/2" thick x slightly over 2"? Or is S7 good enough where I should just buy it? I found a 2' length of 1/2" x 2.5" S7 for $45. Is that better than trying to forge the H13? It's cheaper than the same length round H13. Its also somehow cheaper than 4140 in flat in the same size. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 27, 2021 Share Posted July 27, 2021 (edited) My wife made her guillotine tool to fit heavy truck leaf spring size for the dies. It's 5160 and we use them normalized. They don't mushroom bend or break and the springs are free from a truck repair shop near us. I also have made some fullering dies out of mild steel and the only mushrooming is on the struck end if the stock gets too cold, which is easy to grind out if the top die is long enough. Edited July 27, 2021 by Irondragon ForgeClay Works Add picture Quote Link to comment Share on other sites More sharing options...
JHCC Posted July 27, 2021 Share Posted July 27, 2021 I would strongly suggest that you start with mild steel dies for at least the first couple of hammers. Once you've experienced what a total pain it would be to do all that work with a hand hammer and a guillotine, you might reconsider the "no power hammer" thing, and you won't have invested a lot of money in tool steel. Quote Link to comment Share on other sites More sharing options...
Frazer Posted July 28, 2021 Share Posted July 28, 2021 H13/S7 are overkill for something like a guillotine die. Especially a fuller. The high tempering range make those tool steels great for items that need to be sunk into into hot steel and maintain their shape... hammer eye punches and slitters come to mind, but you really don't need it for either of those tools either. I use 4140 for my dies, but one could use mild too. If the struck end starts to deform, heat it up and straighten it out again. Another, IMO, easier option would be a spring fuller. At the end of the day, either one would work fine. Quote Link to comment Share on other sites More sharing options...
BradleyB Posted March 17, 2022 Share Posted March 17, 2022 Blacksmithsdepot has 4140 die blanks for $30. It's just an 8" piece of 3/4" thick, 2" wide 4140 that you shape to whatever die you need and heat treat. Bought myself 2 of 'em a while back to make my own guillotine tool...have yet to finish it, but I have the dies! Quote Link to comment Share on other sites More sharing options...
Michael Posted March 18, 2022 Share Posted March 18, 2022 I'm getting ready to cut some 4140 dies from Cloverdale forge to fit their guillotine. 3/4 by 2, and just a bit hefty for my metal saw. Gonna use a nearby friends big Ellis to cut 45 degrees and make a butcher dies. My arm hurts just thinking of hand forging H13 into shape for die stock. Michael Quote Link to comment Share on other sites More sharing options...
