Adriaan Gerber Posted July 27, 2021 Share Posted July 27, 2021 I've been trying to use my 20 ton press to press a 1" circle into 1/4" flat stock. I managed a few, but the die deforms too quickly. Is this just a difficult task for a press or are there ways to make this work better? Attached is a picture of what I'm making. Thanks, all. Quote Link to comment Share on other sites More sharing options...
LeeJustice Posted July 27, 2021 Share Posted July 27, 2021 I cannot tell what is the scale of the picture. Is that entire thing the 1" slug you pressed out or is the hole I see in it the one inch? Quote Link to comment Share on other sites More sharing options...
Adriaan Gerber Posted July 27, 2021 Author Share Posted July 27, 2021 The hole is 1". Haven't figured out how to press a slug Quote Link to comment Share on other sites More sharing options...
JHCC Posted July 27, 2021 Share Posted July 27, 2021 Sorry, I'm not getting what you're saying. What are the dimensions of your starting piece and what are the desired dimensions of the piece you are trying to make? Quote Link to comment Share on other sites More sharing options...
Goods Posted July 27, 2021 Share Posted July 27, 2021 Can you provide a sketch of the final part and a picture of your current tooling? That may clear up a lot of questions. Also, what material are you using for the tooling? To me it looks like you are trying to do too much in one operation, but I’m not sure what the final part is meant to look like. David Quote Link to comment Share on other sites More sharing options...
LeeJustice Posted July 27, 2021 Share Posted July 27, 2021 A slug is just a term for the material removed from punching the hole. For the others, the picture is the finished part and the hole in it is the 1" hole being pressed out. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 27, 2021 Share Posted July 27, 2021 Are you trying to punch a 1" hole in 1/4" steel? If so are you doing it hot and how is the piece supported to allow the punch to work? How fast is your press? Quote Link to comment Share on other sites More sharing options...
Adriaan Gerber Posted July 27, 2021 Author Share Posted July 27, 2021 I start with a bar 1" by 1/4". I just want to press a 1" circle about 1/8" deep into it. I used a piece of 1" high carbon from a driveshaft. The press is for forging, fairly fast. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 27, 2021 Share Posted July 27, 2021 And this is done hot? Quote Link to comment Share on other sites More sharing options...
Adriaan Gerber Posted July 27, 2021 Author Share Posted July 27, 2021 Hot, yes Quote Link to comment Share on other sites More sharing options...
LeeJustice Posted July 27, 2021 Share Posted July 27, 2021 I thought that I understood, but I think that I did not. Are you trying to stamp the stock like a coin might be made? Quote Link to comment Share on other sites More sharing options...
JHCC Posted July 27, 2021 Share Posted July 27, 2021 1 hour ago, Adriaan Gerber said: I just want to press a 1" circle about 1/8" deep into it. Okay, so NOT punch a hole all the way through, but to forge the circular recess? Can you give us a picture of the tooling, so that we can see how it's deforming? Quote Link to comment Share on other sites More sharing options...
Adriaan Gerber Posted July 27, 2021 Author Share Posted July 27, 2021 I can get a pic tomorrow. Yes, like a coin. Basically the tool domes over with time. So the surface becomes rounded. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 27, 2021 Share Posted July 27, 2021 If that is a problem you need to make your tooling from an alloy that stays hard even when hot; like S-7 or H-13 both of which have heat treats doable by blacksmiths and both stay hard quite hot! (The draw temp for tempering is in the glowing range!) Press tend to have long contact under pressure on the hot workpiece and so profit from high alloy tooling. Quote Link to comment Share on other sites More sharing options...
anvil Posted July 28, 2021 Share Posted July 28, 2021 Its a pretty complex piece. There are 6 depressions around the perimeter. There are twp straight lines. And it looks lime there is a raised round deal in the very center. Are all these details going to be in your finished piece? Quote Link to comment Share on other sites More sharing options...
Adriaan Gerber Posted July 28, 2021 Author Share Posted July 28, 2021 Yes but those I do by hand. All I'm trying to do with the press is that inside depression. Quote Link to comment Share on other sites More sharing options...
