Gary ONeal Posted May 27, 2021 Share Posted May 27, 2021 (edited) Any information on this anvil would be appreciated. Marked Jos Attwood Warranted. 1 0 12. Thanks Edited May 27, 2021 by Mod30 Resize photos Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 27, 2021 Share Posted May 27, 2021 English made, 19th century, original weight was 124# (CWT stamping) should be close to that now. Traditionally made: built up wrought iron body, forge welded face plate---probably in sections. Should ring. What are the ball bearing test results? When I use my browser (Chrome) to search on Attwood site:iforgeiron,com I get 81 hits; perhaps some of what you want to know has already been posted here? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 27, 2021 Share Posted May 27, 2021 That is a good looking anvil and should serve well, depending upon the ring & rebound test which will show if there is any hidden damage like the hardened face plate has become de-laminated or if it's been through a fire. I hope you have read about not doing any grinding, milling or welding on the face plate which does more harm than good. Quote Link to comment Share on other sites More sharing options...
