DarkFire Posted May 22, 2021 Share Posted May 22, 2021 Happy Smithing all, I am located near Hinton OK for any of you seasoned blacksmiths in the area, would love to get in touch. I hopped on this hobby after really just spark in my head to be more self reliant and get back to the roots of man, creating tools and weapons for survival, while not quite applicable anymore the idea of casting and forging sparked my interest. I have read in the forums roughly 4-5 hours worth now scattered over a couple days, wow what a lot of great info. now im asking for some feedback! While there's some things id like to change about the entire set up this is what I had around and im DETERMINDED to make it produce, like ive read a million times a hole in the ground will do just fine, so I reckon any contraption someone is crazy enough to build could work. Either way gonna try and report back! I have a 10 gallon galvanized Steel bucket, I am lining it with fire clay for added insulation, using steel piping for air inlet fed by a hair drier, I absolutely want to get a hand crank later on, just workin with what's on the property. I intended to add 2 sets of grating 1 for the crucible to sit on, 1 for the fuel source to sit on, and fall through as needed, this bucket will be sitting on a wood table with a hole cut through matching the hole in bottom of bucket for ask droppings, there will be a steel sliding door that can be pulled to both create an updraft and allow ash to fall into the bucket below, which will be sitting of a fire clay block, as well the top of the table will be lined in the clay. I have also added an exhaust tube, same steel pipe as the air inlet, however will be putting a flapper on it, thinking to keep it where the pressure of the gas and smoke from fuel will force open as need be to not let temps drop but let gas formation escape. Hopefully at least! as far as the rest, it will be double lidded with the galvanized lid, as well a clay lid. Im not quite sure this is necessary from my readings as ive seen countless open top fires, and may not need it, however going to construct anyways would rather be prepared than not. I have a drawing I made up of it, hopefully my words were visual enough to help the picture make sense. I would love and appreciate any and all feedback on this design, improvements, changes. Coal isn't necessarily hard to come by but its not quite easy either. not planning to melt high temp metals right off the dot, or am I. either way, looking at grabbing a couple bags of charcoal, no not the grilling kind, I promise I been reading! and I got some feed corn already around and found the corn v coal situation highly interesting, so will be attempting both soon. also one last thing, for the fire clay, I know it needs to be baked for hardening, I was planning to just do a wood fire at first, and then upon further inspection and cooling if all goes well start playin with fire and see if I can't melt something. Thanks! Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted May 22, 2021 Share Posted May 22, 2021 As your in Oklahoma, my first suggestion is to join the Southfork craftsmen. The are your local artistic blacksmith association. You don’t have to join, any one is welcome at a meeting, but you do get access to the club coal piles. I live in Bradley, that is south of OKC about 40 miles. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted May 22, 2021 Share Posted May 22, 2021 Dear Darkfire, Welcome aboard, good to have you. It looks like your furnace is more designed to melt metal for casting rather than getting it hot for smithing. Correct? Others with more expertise regarding casting furnaces can comment further but the only possible problem I can see is your mention of a damper in the exhaust flue. That may well cause back pressure and keep the combustion products near the fire which will reduce the draft and limit the oxygen input to the fire. Also, insufficient oxygen can cause the formation of carbon monoxide, a BAD thing. So, I suggest controlling the fire by placing the damper/butterfly valve on the intake side of the fire and let the combustion products flow out freely. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 22, 2021 Share Posted May 22, 2021 Welcome aboard Dark Fire, glad to have you. If you'll put your general location in the header a member living within visiting distance is much more likely to think of you. Just saying where you are in one post isn't going to stick in anybody's memory after we open another post. Heck I've had to scroll back up twice while skimming the thread now. As George says, what you've drawn is more of a melter than forge. A furnace built to do both melt and heat for smithing purposes most often does neither well. The #1 thing that jumps out as a, NO, don't to THAT!!! is using a galvanized bucket, burning zinc smoke is toxic and has caused deaths. So, unless you strip the galvy off the bucket, soaking in vinegar works a treat, I STRONGLY dis-recommend using that bucket. Another rapid fail point that jumps out are the grates. Whatever you use they'll be wear Items, and might melt outright. A bottom blast isn't a very common way to fire a solid fuel melter. Have you considered how you'll recharge the fuel during a melt? Remember, handling molten metal is extremely hazardous and can not be made risk free. The more times you have to lift the HOT crucible the the greater the danger, Risk rises exponentially for this sort of operation. Speaking of spills I don't see precautions against an internal failure causing a molten metal spill. Say the previously mentioned grate supporting the crucible fails and the crucible turns over. The casters I know have their melters either outdoors or in a sand pan/box and they pour over sand. DRY sand! Any moisture molten metal contacts WILL result in a steam explosion, a couple little bitty spatters if you're LUCKY up to blowing the entire melt all over the shop and YOU. In high school metal shop one of the class clowns stuck a piece of wet aluminum in the crucible in the melter. No rules applied to . . . Anyway, how he avoided being hospitalized and permanently maimed by burns escaped everybody taking the class with him. The steam explosion emptied about 15lbs. of molten aluminum from the crucible by blowing it to the steel: smoke, flame, molten aluminum jet, etc. proof overhead hood that covered the entire hot area. It hit the hood hard enough to cause a wide but shallow dent and splashed about 30 feet in two directions. There were vertical sections in the hood, one on the edge and others sectioning it for this kind of event. Call these curtains. They contained the splash for the most part. Sorry, long story and happily nobody got burned worse than a couple blisters from trying to pick up some cool puddle shaped aluminum. I have one somewhere in a box, probably in the parents garage in Washington. Anyway, it's a cautionary story and really happened, I was well within the splash radius and was one of several people who yelled NO!! when he lifted the lid on the melter with a dripping wet casting he'd ruined by breaking it out of the mold early then cooling it under water in the sink. It was iron oxide sponge. I highly recommend you take a couple casting classes before you attempt melting anything, even lead or zinc can maim or kill you and burn the house down or light the countryside on fire. No joke. I'm not trying to dissuade you from making your own melters, casting is almost as much fun as smithing. I'd just really prefer you knew enough about what you're doing and facing safety wise to minimize the truly horrific injuries even a low temp melt can do you and yours. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 22, 2021 Share Posted May 22, 2021 Along with what Frosty said, be sure and get the very best PPE (personal protection equipment) designed for casting. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted May 23, 2021 Share Posted May 23, 2021 And get and use LONG tongs for lifting a crucible of molten metal. Physically rehearse every movement of handling molten metal with everything cold, placement of the mold, lifting the crucible out of the furnace (load it with cold metal so that the weight will be similar), and the motion of pouring the metal into the mold. Also, always have a space and direction you can jump if things go wrong. As Frosty says, casting molten metal is very cool and fun but it can be VERY dangerous, even in small amounts. He is also very correct in pointing out the galvanized or plated metal and heat are a BAD combination. You don't want to even boil your tea water in a galvanized pot. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
Goods Posted May 23, 2021 Share Posted May 23, 2021 Also, make sure you working area is not concrete. If something goes wrong and you end up with a spill, you don’t want to have spalling concrete and molten metal filing around at high velocity! David Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 23, 2021 Share Posted May 23, 2021 As drawn the ash dump in the bottom would PROBABLY serve as a spill drain. You'll need a large pan of sand under it though. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
DarkFire Posted May 23, 2021 Author Share Posted May 23, 2021 On 5/22/2021 at 1:29 PM, Charles R. Stevens said: As your in Oklahoma, my first suggestion is to join the Southfork craftsmen. The are your local artistic blacksmith association. You don’t have to join, any one is welcome at a meeting, but you do get access to the club coal piles. I live in Bradley, that is south of OKC about 40 miles. Okay! I will look into this, thank you! 23 hours ago, George N. M. said: Dear Darkfire, Welcome aboard, good to have you. It looks like your furnace is more designed to melt metal for casting rather than getting it hot for smithing. Correct? George, Thank you! The goal is yes to melt, cast, then hot forge. For the exhaust would you say rather than a spring loaded flap maybe more of a smoker style flap that pivots and I can release by control rather than pressure and lose the risk of that build up and loss of oxygen? As well after the test burn I for sure would like a valve on air inlet to control the flow. Thank you! Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 23, 2021 Share Posted May 23, 2021 NO. The flap over the exhaust is a B A D idea, it interferes with almost everything to no good purpose. George explained it well in a previous post. You should NOT be concerned with covering the exhaust port at all, it should NOT be a design question. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
DarkFire Posted May 23, 2021 Author Share Posted May 23, 2021 (edited) 23 hours ago, Frosty said: Welcome aboard Dark Fire, glad to have you. Frosty The Lucky. Frosty, Will add my location there, after trials last night I can absolutely see what you mean by neither both. We did utilize the bucket, and stayed upwind from it, seems as though any coating to have existed on it was torched away fast, do you have a better recommended for melting? I would like to get more of an open top table style for the forging portion but feel the melting side needs some renovation. correct there are no fail safes yet, last night was more of a fire practice run, see how everything worked, practice with fuel source, (we used feed corn, and little bit of wood. placing the empty crucible in and seeing how it reacted as the platform of fuels below it shifted. I have a couple years experience working at a big foundry up north, have seem some crazy things with molten metals, absolutely understand how dangerous there are and rest assured no metal will be melted until many changes have come! Thats a crazy story and I don't disbelieve it one bit. We must respect the molten metals. However I have NEVER built a small scale melter, so absolutely new side for me. I have some casting classes ill be in later as well that I am signed up for. like I said, this is goin to be a slow studied process. Ultimately learned a lot last night, and learned a lot that needs to change, from set up, running, handling, design. however it was a successful night with absolutely no issue. Thank you for your help! lots of great info to take into mind. 21 hours ago, Irondragon ForgeClay Works said: Along with what Frosty said, be sure and get the very best PPE (personal protection equipment) designed for casting. Yes, when we actually start messing with melting attempt I have full casting PPE from an old job where I was around molten metal constantly. and will be gathering more. 14 hours ago, George N. M. said: And get and use LONG tongs for lifting a crucible of molten metal. I definitely need some more sets of tongs for handling, we practiced working the empty crucible with high temp metal in there to practice handling the crucible in and out pour etc with some weight in it. Checking that metal constantly to make sure by some luck we weren't melting with a sand pile ready to dump into if need be. Do you have a recommended change from the bucket as well? 14 hours ago, Goods said: Also, make sure you working area is not concrete. If something goes wrong and you end up with a spill, you don’t want to have spalling concrete and molten metal filing around at high velocity! David Do you think for melting like this it would be better over like a big sand box? Thats what I was thinking of changing to, building a box around it fire clay the wood and then fill with sand so if any meltdown happens, spill happens, etc it goes into that vs on dirt, ground or concrete. Thoughts? 27 minutes ago, Frosty said: As drawn the ash dump in the bottom would PROBABLY serve as a spill drain. You'll need a large pan of sand under it though. Frosty The Lucky. Would that be bad? The whole melter will be sitting on a big fire clay lined sand box (unless that changes) so that any failure will release there not anywhere else, unless its a upward boom of course. However do you think that pull trap door would work to drop ash and keep the pile down able to keep feeding fuel? 16 minutes ago, Frosty said: Very well! Open exhaust it is! Edited May 23, 2021 by Mod44 excessive quotes - please trim your quotes Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 23, 2021 Share Posted May 23, 2021 It's been a long time, I'm sure someone with a better memory will come up with it or post a link. I THINK it was LIndsey publications, maybe? There was a series of books or articles with designs for all sorts of things, sort of a "Mother Earth News" approach. Anyway, there were a couple designs, start to finish for charcoal melters. They included lift tongs, T handled pouring ring and instructions for basic construction. Were I making a charcoal melter I'd build it out of fire brick and forget heat loss. It'd be just a little wider inside than the crucible and not much higher. The plinth would raise the crucible more than say 5" off the floor. There would be an air belt surrounding the plinth about 1/2 way from the floor. The plinth would NOT be sitting on the floor, it would be fit into it so it couldn't be moved by anything that wouldn't knock the melter apart. I'd charge the fire through the brick size charging port in the side. Move the brick shove fuel in, move it back. I typically use a 12v dc mattress inflation blower for field expedient forge super chargers. I adjust the blast by how I align the blower with the tuyere. It's too easy and effective to change methods. I'd use an inspection mirror to peak in through the exhaust port in the lid to check the melt. When it's ready I'd lift the single piece or clamped brick lid with my engine hoist or a pivoting lever if the engine hoist isn't available. Say friends and I are doing this on a camp out hammer in. Kill the blower. Lift the and put the lid on it's safe spot. Use the FITTED lift out crucible tongs, place the crucible in the Pour shank. The trusted helper I've rehearsed the operation with until it's completely choreographed and I pour the molds. The crucible goes back in the melter and it's closed up to cool gradually so everything lasts longer. Place the crucible upside down to cool so the crud that always sticks has a chance of falling off. A boy can get lucky once in a while can't he? One of my favorite melters though I've never seen one in person lifts off the crucible and a C ring shank can be slipped under the crucible to pour. All the handling up to the point of applying the C shank is to the melter itself. I'd want something to prevent the melter from swinging during the lift but that's just a detail. This method exposes people to the least radiant heat as the open end of the melter is facing down and I suppose could be lowered back over the plinth while molds are being poured. I'm not a fan of lifting and setting it twice when hot though. If it works better and is safe I can get used to things I'm not fond of. I would NEVER cast on a table top. I want ANY spill to be as close to the catch pan on the ground as possible. Even catch pans don't always work. Imagine you have the melt ready to lift and pour and a stray mastiff chases a squirrel under the table and the melter takes a tumble along with the catch pan. Sure, that's a fine example of linear extrapolation but if metaphorical Mastiff ran into the melter on the ground nobody would have molten metal pouring off the table at waist height. The lower this kind of badness happens the closer to ground zero it stays. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
DarkFire Posted May 23, 2021 Author Share Posted May 23, 2021 All, Thank you tons for the information! I would now like to let y'all know how the test fire went issues we had and successes we had. About 4 days ago we started the build by creating the insulation from plaster of paris, play sand, and water. This was going to be scrapped as it was just leaking and almost sweating out water for about 2 days. The bucket was placed outside as we finally got a sunny day and that seemed to help harden up. we let it sit for another day. Then yesterday it was hard enough to support itself but still not hard enough to do anything with. We built a wood fire to see if that would bake it and harden it. First we learned this, were not as good at starting a wood fire as we thought we were. We finally got a good fire to take, and stated practicing adding air into the fire, needless to say the kid came out in us for a second when it started roaring. Who would've thunk just a little controlled air would take a fire to a full blaze. We burned wood in it for about 4 hours, practicing getting that to a full blaze down to a calm fire, back up and out. Then practiced more how to get a quick fire going. Once we got that going comfortably we grabbed feed corn. Now remember we are not fully equipped for the science side of the house yet. Here is how the corn fire went. I don't have any numbers, or rhyme or reason but I can tell you we learned how get corn burnin, and how to get it HOT. Through many failed attempts of course. Please read for those curious on the corn side! We had a good little fire going, wood base just little, then dropped a handful of corn into the fire. this smothered the fire and almost immediately put it out. We got the wood to catch but couldn't quite get the corn to catch immediately and that was creating lots of issue. Eventually we had a small struggling flame and way more corn than needed. We got the fire out, and cleared the pot to try a fresh start. The second run we lined the edges of the bucket above the fire to hold corn (tried to copy coal style of feeding in piece by piece) we got a few pieces of wood going and let that burn for a bit, we noticed the corn would start to scorch up a bit and started to push those ones in just a couple at a time. these would drop in and crank out a hot blue flame, we finally got the fire to about a 90% corn fuel and 10% wood (left over charcoals) and following the same method it seems as though heating the corn up by fire first then introducing it into the direct blaze allowed it to absolutely roar and then drop down and coke up into great powerful clumps that burned amazingly. When we got that figured out we started introducing air and that fire was HOT. We had blue, orange, and pinkish flames without yellow in sight just raging through the bucket. While do to design we are unsure if it would have for sure melted or not but I am 100% confident with the right set up that fire would have melted. We let that fire burn out, collected the coke and charcoals formed through the last burn. Then did one last burn this was an attempt to see how quick (safely) we could go from empty bucket to blue and orange corn fire. We started with even less wood, and had corn on the bottom under the wood a small coating, as well the edges with a heavy coating. Once the fire was established and the outer walls stated cooking, we started sprinkling that corn in and very quickly did we have a roaring blue based fire with no input air we started applying air and it quickly came to life and boom we had a beautiful HOT fire roaring. The corn did seem to burn quickly, we found we could kinda tap the bucket with the tongs and it would vibrate the corn in. But seems you need to have quite the stockpile ready to go as it burns fast and very powerful. We did throw the crucible in on the last burn to get some practice putting it in, pulling it out, and pouring into molds. As far as molds go, we learned were not so great at that and if anyone has a good mix for making molds id love to hear it! Again remember folks, this was a first time, with lots needing to be changed. Safety to be applied, and lessons learned. Share the knowledge, help us to be better safer blacksmiths, and we are HOOKED. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 23, 2021 Share Posted May 23, 2021 Corn has been discussed as forge fuel pretty thoroughly a while back. It does NOT like a bottom blast particularly well but it behaves in a similar manner to coal as it pyrolizes. As it gets hot enough to start shedding water, keytones, esthers, etc. it swells and sticks together in clumps just like coal does as it pyrolizes. Coal ad Corn contain a lot of oils ad tars that wood doesn't. Trying to light corn from the bottom or feed it from the top runs into the problem of it swelling, sticking together and blocking flow through it, air is blocked from entering and exhaust products can't get out. This is probably why it kept going out on you. Give it a try in a sideblast forge like a JABOD and enjoy the heat. You bet it'll melt, you didn't say what you hoped it would melt but I'm going out on a limb here and saying. If it's less than a high temperature alloy yes, it'll melt it. It'll melt your crucible, the kaowool, kastolite, probably plistex kiln wash. Not zirconium though, that'll be safe as will tungsten, monel, inconel and other rocket / jet engine alloys. Another serious mistake you made is using Plaster of Paris (PoP) in a forge liner, in any way, except maybe the walls in the room. No POP, it can NOT withstand much more than 230f before it begins degrading, water isn't bonded molecularly well enough to prevent it disassociating at much above boiling temp. around 230-240f IIRC. Happily though it doesn't fail as spectacularly as Portland cement concrete, PoP tends to crumble sometimes kind of actively but concrete spalls explosively sending hot sharp flakes flying fast enough to do you a serious mischief. Steam explosions do that. Corn isn't likely to work in your melter as designed. Well, not well enough to be a practical fuel. There isn't much oil in rice you know. <evil grin> Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted May 24, 2021 Share Posted May 24, 2021 Probably one thing to consider when using corn as a fuel is its moisture content. If it has much moisture it may resist burning and in a worse case scenario cause a small steam explosion which is what happens with pop corn. I know that corn sold as feed corn has to have a certain minimum and maximum moisture content but do not know how that compares with corn sold or used as fuel. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 24, 2021 Share Posted May 24, 2021 Flee to the gingerybookstore.com and invest in his pamphlets on building and running a charcoal fueled furnace and perhaps those on casting Al as well; shoot you could splurge and get the one for a propane fired furnace if you wanted too. These books are a well known and proven in resource. (I note that there is a number of youtube videos on people using such things built (hopefully!) to his plans.) Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 27, 2021 Share Posted May 27, 2021 That's what I was thinking of! Gingery's pamphlets. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
DarkFire Posted May 27, 2021 Author Share Posted May 27, 2021 Thanks fellas! Will intake all this and apply to the future JABOD build that will be coming soon. Going to use the red dirt clay around my property (western ok) test burned some that I gathered and it hardens up real well seems to work perfect. Lots of revamps more up to “code” are coming. As well a plan to build a “melter” and a “hot forge” if my terms are correct to the blacksmithing world. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 29, 2021 Share Posted May 29, 2021 Did you add sand to the native clay? If not it will shrink check and you'll have cracks running all over it. Hot forge isn't a type of forge Hot is an adjective in this sense, "Watch OUT that's a HOT forge!" The basic types of forge are solid fuel and gas. There are different solid fuels and gasses. Generally we talk about Propane forges as they're in the most common "gassers" use. Europe is different NG or methane is more common so they more typically run NG forges. I'm not trying to be picky but learning the jargon makes meaningful communications possible without having to describe everything you ask or say. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 1, 2021 Share Posted June 1, 2021 Also understanding that this is an international site and what is common and "THE NORM" where you are at may be an outlier where other people are smithing. Quote Link to comment Share on other sites More sharing options...
