JHCC Posted May 5, 2021 Share Posted May 5, 2021 I've recently acquired an old Lincoln buzz box and need to teach myself stick welding. I have a line on some old welding rod for cheap, and I'm wondering if I might be able to make good use of it while I'm learning to strike arcs and lay down beads. Some of the older threads (like this one , this one, and this one) have what looks like good information about using old welding rods, mostly along the lines of "rebake 7018 for non-critical applications, don't self-sabotage your learning with bad electrodes, and strip the flux from the worst rods to reuse the steel." Any additional thoughts to help me make up my mind? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted May 5, 2021 Share Posted May 5, 2021 Standard 7018 rod is a challenge to use with an AC only buzz box. The 7018AC rod works much better, but I always end up using significantly higher amps than the same diameter of 6011 or 6013. For 7018 rod especially, keep an old file nearby that you can use to rough up the end of the electrode if it has cooled down. That makes striking your next arc much easier. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 5, 2021 Share Posted May 5, 2021 Using old rods is rather like forge welding; it's a harder technique to use for beginners; but a lot easier for experts! (Also don't use dubious rods for mission critical applications!) Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 5, 2021 Author Share Posted May 5, 2021 What about for practice padding beads? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 5, 2021 Share Posted May 5, 2021 Arc is often harder to strike and maintain. Your call. Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted May 5, 2021 Share Posted May 5, 2021 Can you tell us the type and size of electrode that you anticipate acquiring? Robert Taylor Quote Link to comment Share on other sites More sharing options...
arkie Posted May 6, 2021 Share Posted May 6, 2021 JHCC, just starting out, practicing with old rods as you stated you have read, is not a good idea. The old rods will not let you see how the bead is supposed to look and weld like a new rod would. The fluxes on the rods were designed and engineered to perform in a certain manner to produce a proper weld. The flux on old rods has degraded to various levels and will not protect the weld and produce a proper weld. If you want to practice stick welding in a proper manner, take the leap and buy new rods of whatever type you will be using. You can develop some bad habits trying to perfect your welding by using old rods and then when you decide to weld something important with new rods, it will be a whole new learning experience. Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 6, 2021 Author Share Posted May 6, 2021 Good explanation, arkie; thank you. Robert, there are a couple of options. My favorite industrial surplus place has the following interesting items: An unopened box of 1/8" Eureka #26 (6013) rod An opened box that's labelled E7018 rod but that actually contains two or three smaller containers of Blue Devil E7024 rod; don't know the size A plastic bin with a bunch of different types of loose rod, mostly 7018 and 6011; many different sizes A big plastic bin with a LOT of loose 7018 that looks in pretty good shape (apart from not being in sealed containers); don't know the size A large-ish metal bin with a whole lot of different rods. Some of them are clearly well past usability, some are marked with manufacturers and their specific codes that I haven't (yet) been able to identify, and there's a lot of 7018 as well. I think there are also a few aluminum rods as well. Frankly, the price is so cheap I might just get this for the bin. Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted May 6, 2021 Share Posted May 6, 2021 First off, what Arkie, Buzzkill, and Thomas said. Buy a pound each of new 6011, and 6013. I would say, as others have, do not try to weld with surplus 7018, someone I know got a great deal on old 7018, and he might as well have just poked himself in the eye... I love old, nearly free electrodes with the flux knocked off, to lay down in weld fitup gaps, to feed filler metal while stick welding (Texas tig), upsets nice, should forge weld nice... Should be able to get the cellulose off of some of it by running it under your car tire... Robert Taylor Quote Link to comment Share on other sites More sharing options...
Glenn Posted May 6, 2021 Share Posted May 6, 2021 Use the old welding rods for the metal, 1/8 x 14 inch metal rods. Plenty of projects when you have a supply of the metal. Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 6, 2021 Author Share Posted May 6, 2021 Good info; thank you all for sharing your experience and advice. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted May 7, 2021 Share Posted May 7, 2021 Most of that rod looks fine to me. If it is dirt cheap get some and try it out. But as said before an AC buzz box is not good for 7018, and 7018 can be baked to dry it out. I love 7018 on DC reverse polarity. It lays down so smooth and the slag literally lifts off of the bead. For an AC buzz box look for 6011 , we called it farmer rod because it would burn through rust, dirt, manure, etc.. Quote Link to comment Share on other sites More sharing options...
arkie Posted May 8, 2021 Share Posted May 8, 2021 There are two basic types of 7018 rods. 7018 for DC; 7018AC for the AC machines. Each "will" run on the other machines, but poorly. I too, like to use old electrodes for the metal in them. I strip the flux off with a wire wheel on my bench grinder and use them for all kinds of things around the shop. Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 12, 2021 Author Share Posted May 12, 2021 On 5/6/2021 at 9:51 AM, JHCC said: A large-ish metal bin with a whole lot of different rods. [...] Frankly, the price is so cheap I might just get this for the bin. Someone got there ahead of me. Oh, well. Quote Link to comment Share on other sites More sharing options...
Pierre M Posted May 13, 2021 Share Posted May 13, 2021 Not a pro welder by any mean by I own and run 5 or 6 welding machines (mig tig arc) between our mill shop and horse farm. Self taught and have the scars to prove it... I do burn on a daily basis from excavator repairs to small tube, stainless etc. rods are cheap and the only reason to use crummy rods is when you ran out everything else ,in a pinch, and only on a non critical repair, knowing it will eventually fail... I do not like giving advice but when asked by beginners I stick with the following line ; cheap tools and supplies can result in an ok job at the hands of a pro , after much swearing generally, and total failure at the hands of a beginner... why setting yourself for failure... would anyone teach their kid on a car without brakes clutch and blown shocks ? (Aside for picking hay bales in a field) get the best consumables possible period., buy them in small quantity from a reputable welding shop... 7018 is a dc rod unless specifically rated ac (do not like the way they burn) I favor Lincoln Excalibur 7018. Most will tell you I’m wrong yet I will not do a job with 7018 unless out of a brand new sealed can immediately stuffed in my rod oven and kept there ... I only pull them 2 or three at a time. rebaking 7018 is pretty much xxxxxx they need to be in a oven at proper temp until burned or they will no longer be up to snuff... Rod ovens are cheap... otherwise use another type of rod ... Pierre Quote Link to comment Share on other sites More sharing options...
arkie Posted May 13, 2021 Share Posted May 13, 2021 With respect to 7018 DC rods, the use of rods coming from a new sealed can or rod oven at the prescribed temperature is commonly a requirement for code structural welding. For everyday welding, the rods don't have to adhere to the requirements for code work. They do however, need to be kept in a dry environment. Quote Link to comment Share on other sites More sharing options...
louis sham Posted May 31, 2021 Share Posted May 31, 2021 (edited) If there is any rust on the road, if the flux has formed a dry, powdery coating, or if the flux has softened, the rod is bad and should not be used for anything other than non-critical welding on mild steel. if welding electrodes absorb moisture on the flux, it can cause bubbles to develop in the weld. So please visit this website for more details about welding [commercial link removed] Edited May 31, 2021 by Mod34 Commercial link removed Quote Link to comment Share on other sites More sharing options...
arftist Posted November 13, 2021 Share Posted November 13, 2021 Really need to know whether you have AC-DC -or just AC. If AC only, buy 7018 AC only. All old rods should be dried. 250 degrees for an hour in your kitchen oven is better than slobbering can't start an arc wet. Most of those rods you don't want unless you have DC. I personally have little use for 6013 but I have MIG welders. As Gun Dr. said 6011 is all around rod. Fast freezing it can fill large gaps and poor fitup. Digging arc does not mind some rust and dirt and can weld through paint if need be. Note that all welding purposes prefer clean metal and good fitup can be a component of strength. I would buy a fifty pound can of 1/8" 6011 to start with. That will be good for 90% of your repairs or fab projects. After a few cans you can say you know how to weld. After a lot more cans you will be a welder. By then you will be well versed in 7018 as well. 7018 is required for all structural welding and also for higher alloys such as plow steel and other tool steels. When doing these type of welds good well preserved dry rods are always required. xx24 rods are high speed good fitup flat position rods and require mad heat. Even 1/8" is likely too big for you. Quote Link to comment Share on other sites More sharing options...
