Eli89 Posted May 1, 2021 Share Posted May 1, 2021 Hi guys, Thanks in advance for your help. I recently bought a devil forge 3 burner unit. It seems great and I've put the fire wool (not sure correct name) in and then coated it with the rigidizer that came with the forge. I've been reading a few threads that seem to indicate that I should put a layer of Kastolite-30 on top of the rigidizer and some sort of UV coating as well. Is anyone able to confirm whether or not I need more coatings (and recommend which ones) in addition to the provided rigidizer and if so do I remove the fire bricks before coating and do I coat the back door which has the same wool/rigidizer combo. Sorry I know this has been asked but I am new to this and wasn't exactly able to follow the answers provided. Any help and advice is sincerely appreciated.span widget Quote Link to comment Share on other sites More sharing options...
