Bantou Posted May 1, 2021 Author Share Posted May 1, 2021 It’s a temporary set up. So far I haven’t had an issue. The plan is to set it in sand or on a stump once I’m sure I like the height it is at. Once I have it on its permanent stand, I’ll chain or bolt it down. Link to comment Share on other sites More sharing options...
pnut Posted May 1, 2021 Share Posted May 1, 2021 I used a couple pieces of mitre cut wood and a wedge to hold the same anvil to the stump. It deadened the ring considerably too. I got the idea here. It was easier than the chain and bolt set up I was using because I have to take it off the stump when I'm done. If I get out I'll take a picture of it or if I can find the post on here I'll link to it. Pnut Link to comment Share on other sites More sharing options...
Frosty Posted May 1, 2021 Share Posted May 1, 2021 Sitting on a spool like that almost makes tying it down moot. All it needs is to not fall on your foot. When you put a solid stand under your anvil you won't believe the difference. Your projects will go much faster and you won't be so tired at the end of a session. You can make a spring butcher for shouldering from square mild stock and it'll work fine for a while. If you use a spring tool you can put kiss block in it the same thickness as the shank you wish to make and it's a done deal. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Bantou Posted May 6, 2021 Author Share Posted May 6, 2021 The tie downs are mostly just to keep it from dancing around on me. I’m going to make a base out of old cross arms soon. At 4x6”x8’, they are a good size and they have pre-drilled holes in both sides that conveniently all line up perfectly. They are also treated agains weather and bugs. I’m just waiting on enough DA bolts (5/8 all-thread) to show up in the scrap dumpster. Link to comment Share on other sites More sharing options...
Please sign in to comment
