Paul TIKI Posted April 7, 2021 Share Posted April 7, 2021 (edited) This is a topic to see if I am on a decent track or if I am simply insane. I have just been getting started and have been getting more and more frustrated with my solid fuel forge. I just don't seem to be getting the kinds of temps I want with any consistency. I also can't seem to figure out how to build things with what I have in order to be able to heat different parts of the metal when the piece is long or oddly shaped. I'm also frustrated that wind and the weather keeps me from lighting the forge as often as I'd like. I do understand that this mostly speaks to my impatience and inexperience, but.... I'd like to build a gas forge for as little monetary investment as I can, using mostly what I have lying around. There are several things I know I will have to buy and I do not want to skimp on safety. So here is what I have in mind. The forge body, I think I have an old party Helium tank in the basement. It's a bit smaller than a propane tank used with most common gas grills, and the metal is substantially thinner. It's empty, or nearly so and I can bleed it off before cutting. I think I will leave it standing upright as a forge, unless there is a benefit to turning it on it's side. I will line it with rigidized kaowool, probably 2 layers of 1" according to the instructions I have seen pinned on this thread. I'll have to buy the liner materials, obviously. For the shelf, I have some soft firebrick on hand. For the Burner, I am thinking one of two things. The Frosty t-burner is one option, though I will have to buy the bits and bobs to make one, or two, according to the final volume of the forge body. I need to do a lot more reading on this subject. The other Idea that just recently occurred to me would be to create a naturally aspirated ribbon burner. I might be able to carve out an existing firebrick or two. Another Idea that may or may not be possible, feasible, or advisable would be to use the rigidizer material to cast it. Depending on the cost of the needed casting material, I may just do that instead. In short, use existing firebrick, cast with stuff I'll have on had from lining the forge, or buy actual casting material. Or just go with the tried and true T-burner. Here is where the main sanity check is: The regulator. I have the connections and hoses from 2 different gas grills already on hand. the Hoses are not cracked or anything. the connection to the propane tank is in good working order. Is this a decent kind of regulator, or do I need to spend the cash to get one with dial so I can tell how much pressure I am getting. I just don't know enough about these things to be able to judge for myself. Can I use what I have or is it plain and simple safer to buy new stuff. It's going to be a long process, probably taking most of the summer to get there as I buy the bits a little at the time. And yes, In the mean time I'll keep practicing with the charcoal forge. I have also thought of using firebrick to build the whole body of the forge, but I have zero welding skills to make a framework What do you guys think? Am I missing something and is the proposed reuse of the existing connection materials from the gas grill nuts. Edited April 7, 2021 by Paul TIKI added something I forgot Quote Link to comment Share on other sites More sharing options...
Latticino Posted April 7, 2021 Share Posted April 7, 2021 Not to rain on your parade or anything, but you might want to consider the following: Gas grill regulators are not adjustable and not adequate. A NARB will still need a burner to be made, the perforated section is just the head of the burner. Soft firebrick needs to be rated for at least 2600 deg F to survive for long in a gas forge that is operating at typical forging temperatures. It won't survive regular thermal shocks well, will get eaten by flux, and won't tolerate direct flame from the burner. Helium tanks make fine forge skins (you could even use chicken wire in a pinch), properly constructed the forge skin should have minimal loading and not get too hot. Gas forges are typically more difficult to design suitable for spot heating of things that are long or oddly shaped than solid fuel forges. Wind and weather also affect naturally aspirated gas forges. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted April 7, 2021 Share Posted April 7, 2021 First off. The party size helium tank is fine. There is more than one size, but if it's comparable to a disposable refrigerant (freon) tank then it's a good size for a first propane forge. I used one for a while with a single 1/2" Frosty T burner and was able to forge weld in it. However, if you think you are frustrated with getting odd-shaped pieces placed properly to heat a specific section now, that will only be magnified with a gas forge. Small gas forges do quite well with straight or nearly straight pieces that need less than 12 inches heated at one time, but when you are dealing with a chamber opening which is typically between about 4 and 8 inches in the largest dimension, that does create some additional challenges for irregular stock shapes. Breezes also tend to be an issue for a lot of naturally aspirated burners. However, the NARBs I have built don't seem to be quite as sensitive to wind as the single port burners were. If by "shelf" you mean the floor then soft insulating firebrick is not a particularly good choice. Between the thermal shock of repeated heating and cooling and the mechanical abuse of dragging hot steel across the forge floor an IFB will not last long. If you use flux you could destroy it in a single forge welding session. You're better off with a castable refractory floor or even a split hard fire brick. High alumina kiln shelf is better yet. Regulators designed for gas grills only operate at a couple psi usually and are not adjustable. That's barely enough pressure to make some naturally aspirated burners function, and not enough for others. If you want to build it right then you want an adjustable regulator. If possible you want to get one that can go from 0 psi to at least 20 psi. It's not so much about the "dial" (I assume you mean gauge here) as it is about being able to change the pressure of the fuel going to your burner. That pressure will be a major factor in the temperature achieved inside the forge, and while we caution people not to fixate on specific numbers, you probably won't be able to achieve the temperatures you want using a regulator from a gas grill. You do not need welding skills to build a brick pile forge. Many people have built them with a few pieces of angle iron and some all-thread rods for the main components. Frosty has shown pictures several times of forges built that way at his local club and they clearly work well as they are built. The best advice I can probably give you is this: pick one plan known to function well and strictly follow that plan. Don't substitute or change anything unless/until you ask the designer or a knowledgeable person who has used that design if it will matter. Once you build and understand your gas forge you will be in a position to incorporate changes/improvements into your next one - and there will be a next one. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted April 7, 2021 Share Posted April 7, 2021 Nice summations, Latticino and Buzzkill. Quote Link to comment Share on other sites More sharing options...
Paul TIKI Posted April 7, 2021 Author Share Posted April 7, 2021 OK, thanks so much for the benefit of your experience! So I think I may stick with the helium tank. As is, I think I will have some more options in design. I'm thinking a front opening and a closable back door in case I have a longer piece that I need to pass through to get the heat where I want it. I do know I'd have to buy more bricks for a brick pile, so I'd have to compare that cost with the cost of Kaowool and rigidizer. As to the wind problem I'm currently dealing with, It doesn't so much give me problems with the metal or heat or anything. The big problem is that I don't want ash and firefleas going everywhere. Local farmers frown on people setting the crops on fire. Also, when local authorities say "no Burn", they mean it. Even grilling is frowned upon. I don't think I'd set anything on fire, but polite behavior means happy neighbors. With some basic shop plans running in parallel with a propane forge build I think I'll have a more weatherproof solution. The shop will be some 4x4's sunk in to the ground with corrugated metal walls and roof. Super easy and cheap. It's good to know I'll need a decent regulator. I suspected as much, but I just really wanted to make use of what I have. so, I guess I need to do some cost comparisons and start gathering supplies. Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 7, 2021 Share Posted April 7, 2021 The IForgeIron store carries all the supplies you will need to build your gas forge. Gas Forge Refractories and Supplies Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 8, 2021 Share Posted April 8, 2021 For your regulator and hose check eBay/Craig's list used for weed burners. I bought one for $20 U.S. and free shipping. The burner part is not applicable for a forge but the savings on the regulator and hose is worth it. Mine came with 20 ft of propane rated hose and a regulator that would cost twice what I paid. I can also use the weed burner when needed by disconnecting the forge and hooking it up. I would build the forge horizontal, I tried a friends vertical forge and getting the steel in & out was a chore and it didn't heat the steel as well as our horizontal forge also the long stock couldn't be passed through. Soft firebrick will work for sliding doors although they will deteriorate faster than hard K26 IFB. We used the soft bricks we had on hand because we have a lot of them from the Kilns. When they are used up we will buy Morgan K26 bricks but so far they are holding up just fine. Quote Link to comment Share on other sites More sharing options...
Paul TIKI Posted April 26, 2021 Author Share Posted April 26, 2021 Well, after talking to my son and looking at component costs and so on, It looks like I will not be messing around with the helium tank and instead go for a 6 brick pile gas forge with a Frosty T burner. that will get me a propane forge for the lowest cost. The Boy has decided to leave all of his forging gear here as his landlord doesn't care for the idea of blacksmithing on his property. Since he has some soft firebricks I can use those for the body. I have some scraps I can use for a framework and work shelf. So I can get that far without expenditure. I have seen high pressure regulators with 6 foot of hose on Amazon for 24.99 although I will keep my eyes open for things like used weed burners and such before I actually click the buy button. Plenty of sources for propane tanks. And since we are doing a number of projects that require running too and from the hardware store, I can get a piece here and there to spread the purchase of the burner parts out if need be. I found a pile of taps and dies that dad had, so I need to make sure I have the right ones, but that part should be covered. The Other Boy has a drill press I can use for drilling out that top hole, but If I can I'll try to talk the wife into letting me buy a new drill press. I figure the longer the hose, the better, what would be a minimum safe length in Ya'lls opinion Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 26, 2021 Share Posted April 26, 2021 Longer the hose the more likely to trip on it, run over it, drop heavy/hot/sharp things on it. I try to not have it any longer than necessary. Quote Link to comment Share on other sites More sharing options...
Paul TIKI Posted April 26, 2021 Author Share Posted April 26, 2021 so If I go with something like a 6 foot hose and house the propane bottle say, underneath a 55 gal drum with the forge being on top? Or would it be better for it to be out in the open, so to speak? On a stand next to the forge or underneath? I have a weird Idea now of getting a long hose, running it through a PVC conduit with a couple of right angles and digging a trench and burying it. That way no trip hazard and tank farther away from forge. I'm probably making this more complicated than it needs to be. Quote Link to comment Share on other sites More sharing options...
Goods Posted April 26, 2021 Share Posted April 26, 2021 I’m not sure if this what you mean, but do not put a propane tank in an enclosed area like a 55 gallon drum, or enclosed cabinet. If you have even a minuscule leak, in such a small space it will get to explosive levels faster. You will also be less likely to smell the leak. Be safe, David Quote Link to comment Share on other sites More sharing options...
Paul TIKI Posted April 26, 2021 Author Share Posted April 26, 2021 thanks Goods. This is why I ask questions. It saves ones eyebrows among other things. I hadn't though of the potential for fumes, though I should have. I have a couple of drums and I haven't decided what to do with them. I am thinking of using them in a way that would shield the tank from the heat of the forge. Maybe by cutting it in half vertically and just setting it between the tank and the forge. I dunno. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 26, 2021 Share Posted April 26, 2021 Good call GOODS! I saw Paul's idea was scrolling down and saw your reply. I'm glad I read to the end before responding but holy moly what a frightening rush. Putting your propane tank where things can't hit it is a good idea. I put obstacles between my tank and the forge so nobody will take a short cut and trip over the hose. A hard and fast rule of propane is: never, Never, NEVER put a propane tank in an enclosure! You aren't supposed to have one on a BBQ in your garage. It doesn't matter what was in a drum or barrel before pertaining to putting a propane cylinder in it. Just a LITTLE bit of propane in a piece of PVC pipe will shoot a potato a couple hundred feet. A 55gal drum's worth scares me and I like explody things. I am GLAD you asked, REALLY GLAD! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 27, 2021 Share Posted April 27, 2021 If you have 6-10 feet of hose and place the tank at the back of the forge, you shouldn't have any problem with hot steel hitting it. As far as someone tripping on it, like frosty said block off any access without enclosing the hose or place 2X4s on either side to guard it. I have 20 feet of hose on mine and run the hose off the pad and along the blocks to the 100 pound pig tank. Quote Link to comment Share on other sites More sharing options...
Paul TIKI Posted April 27, 2021 Author Share Posted April 27, 2021 (edited) OK, got it. do not attempt to enclose tank. May cause large boom and that is bad. It really is good to have that point brought up now and again. It helps prevent dabblers and fools like myself from doing something dumb, and in this case potentially lethal. Is there a way to pin parts of this thread into it's own pinned thread? Maybe right along side of "DO NOT USE PLASTER OF PARIS". "DO NOT ENCLOSE PROPANE TANKS" We all know that common sense is not too common. I like to think I'm pretty level headed, but this is a case that brought me up short. Edited April 27, 2021 by Paul TIKI added something I forgot Quote Link to comment Share on other sites More sharing options...
