Hercules 400
Ball bearing test was great,not sure what the ring should be on something that size, base seems to be cast iron but I am not positive. Face looks like it has been recently resurfaced what should the ring sound like? Thanks in advance.
Free floating cast steel anvil ring will be piercing; free floating wrought iron body steel faced anvil ring should be loud and clear, Steel faced cast iron body anvil ring will be more a thwap than a TING, cast iron anvil dull thud.
What percentage is "great"?   We've had folks who said the rebound was great and it was around 45% and we've had folks say it was great and it was 90%.  The whole idea of the ball bearing test is to have an objective number to compare with.
Please NO videos! They're almost always are too shakey and swoop all over the place to be much if any use. Just do the test please, we'll trust you can estimate the rebound even if you use a ruler.
  • 3 months later...
