Posted (edited)
Thanks, Irondragon!  I abrasive blasted and painted everything, inside and out.  I was told the hand-crank gearbox leaked oil, so I flattened all the mating surfaces and used permatex RTV gasket material to seal everything.  I've done a couple heats with coke and it works well.
I've seen the images and read the company history on gracesguide.co.uk.
Thanks again,
Matt
Edited by Mod30
Remove excessive quote.
  • 4 weeks later...
Posted
I use chainsaw bar oil with about 1/4 cup of Duralube to a gallon jug. I put a few drops in the oil ports at the beginning of a session and it lubes it nicely for a days use. Eventually even that little bit seeps out. Chainsaw bar oil is sticky so it doesn't sling off the high speed gears.
