Sam Falzone Posted August 13, 2008 Share Posted August 13, 2008 Hi there, I was wondering if someone may have an answer for this. I have a really old cast iron pot that I cracked a few years back. This thing is huge and hard to replace and really old. Is there a way to weld a cracked cast iron pot and still make it useable (food safe and all that stuff)? If there is, how do you do it? Aeneas Quote Link to comment Share on other sites More sharing options...
Finnr Posted August 13, 2008 Share Posted August 13, 2008 I couldn't do it with 100 percent results. May be others on here who could. Finnr Quote Link to comment Share on other sites More sharing options...
racer3j Posted August 13, 2008 Share Posted August 13, 2008 (edited) in the last couple days we discussed this in this sub or perhaps Prob. Solv.mike--- Problem Solving --4th thread down. Edited August 13, 2008 by racer3j thread location Quote Link to comment Share on other sites More sharing options...
Metal Head Posted August 27, 2008 Share Posted August 27, 2008 Grind out the crack to recieve a weld,then heat with a torch until hot, then weld with some nickle rod,i have done this with cast electric motor housings,it works well,if not find a good welding shop,if they know there stuff you will be pleased Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted August 27, 2008 Share Posted August 27, 2008 lostt cause Quote Link to comment Share on other sites More sharing options...
rlarkin Posted August 27, 2008 Share Posted August 27, 2008 If you just want to patch it make it water tight, v it out and braze it up. To weld properly you need to pre heat, weld with nickel rod, then bury it in sand for a day to cool REAL slow. I have used a rod by Forney called NOMOCAST with fairly descent results and no pre heat. If you plan on using it for a cooking vessel, or something that will see heat, forget it. Quote Link to comment Share on other sites More sharing options...
Travis Covington Posted August 30, 2008 Share Posted August 30, 2008 Just v it out take a nickle rod nock of the flux & sand it clean then tig it. Travis Quote Link to comment Share on other sites More sharing options...
Hillbillysmith Posted September 3, 2008 Share Posted September 3, 2008 It can be done, but if you have never worked with cast before and you want to be able to use it, don't do it yourself because you never know what type of cast iron it is. But depending on how valuable it is to YOU, and depending on how much you use it, you may as well use it for decoration because it won't be worth it to get it fixed. But if you want it fixed, go to the local welding supplier and ask around to see if they know any place that welds cast. Like I said, it CAN be done, but don't do it yourself b/c it's just going to be too much of a pain to deal with. -Hillbilly Quote Link to comment Share on other sites More sharing options...
Sam Falzone Posted September 4, 2008 Author Share Posted September 4, 2008 Thanks Hillbilly. I think I'm going to bring the idea to an old welder/Blacksmith I met 2 months ago (he did another welding job for me then) and see what he says. I've been meaning to go back and introduce myself and hopefully talk some shop with him. Thanks again for the advice. Aeneas Quote Link to comment Share on other sites More sharing options...
PeterDE4 Posted September 5, 2008 Share Posted September 5, 2008 I may have luck doing some things simply because I don't know any better, but I Mig weld cast iron on a regular basis with mild steel wire. I use decorative cast iron panels in some of my railings and gates, and I just Mig weld them to the steel frames. I met a fellow one time who made up metal grills for the windows of his gun store, and he just Mig welded the panels together. I'd vee it out a little before trying it, as some of the other folks have suggested. And, if you have access to a Tig welder, just use a nickle rod. Quote Link to comment Share on other sites More sharing options...
Hillbillysmith Posted September 12, 2008 Share Posted September 12, 2008 Peter, it's not that easy. for ornamental work, MIG welding the cast iron will do just fine. But the object that he is talking about doesn't just need to hold together. It will be frequently subjected to heating and cooling at different rates which will expand and contract both the weld metal and the cast iron at different rates. This will almost guarantee a weld failure ie; cracked weld, cracked base metal, etc. -Hillbilly Quote Link to comment Share on other sites More sharing options...
