Justin Topp Posted March 6, 2021 Share Posted March 6, 2021 I have a Racine 14” power hacksaw and I attempted to connect the coolant but there’s no flow. Pump is clean and in good conditions and lines are clear. I’m trying to use water for testing and the pump is a gear pump. Does it need to be oil? Cutting fluid isn’t that much thicker than water though Link to comment Share on other sites More sharing options...
Jonnytait Posted March 6, 2021 Share Posted March 6, 2021 Is the pump spinning the right way? I have an AJAX power hacksaw which is 3 phase, so it can run backwards if I change up the wiring. The coolant pump doesnt work when its running the wrong way Link to comment Share on other sites More sharing options...
Apple Duck Posted March 6, 2021 Share Posted March 6, 2021 That thing is hopeless. By the way, what do you want for it? HAHA Does the pump require priming? Are the seals if any in good condition. Pretty sure you can get an auxiliary pump from supply house and run it (low voltage) independently if the original setup keeps giving you problems. Link to comment Share on other sites More sharing options...
Justin Topp Posted March 7, 2021 Author Share Posted March 7, 2021 The saw is running the correct direction. So the gear pump should be too. Haha I think I’ll keep it. I paid 300 a few months back and it’s far outperforming my 4x6 bandsaw Supposedly gear pumps doesn’t need to be primed. But I also tried that to no avail. I may have to buy a separate pump but it would be cool to keep the original. Maybe I’ll see about getting some other belt driven pump and hook it up Link to comment Share on other sites More sharing options...
Frosty Posted March 7, 2021 Share Posted March 7, 2021 Oops, nevermind. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Justin Topp Posted March 7, 2021 Author Share Posted March 7, 2021 A worn out gear pump was my issue. It barely trickles when I spin it using my drill in a bucket of water. I found another gear pump and with the same drill in the bucket of water it shot tons of water out. Should be easy enough to fix Link to comment Share on other sites More sharing options...
Justin Topp Posted March 9, 2021 Author Share Posted March 9, 2021 We have coolant! Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 9, 2021 Share Posted March 9, 2021 And there was great rejoicing! Link to comment Share on other sites More sharing options...
JHCC Posted March 9, 2021 Share Posted March 9, 2021 Cool! Link to comment Share on other sites More sharing options...
Justin Topp Posted March 9, 2021 Author Share Posted March 9, 2021 Turns out all it was, was a little metal bb looking ball of rust. When I blew air though it would move and let air through. And than settle back. Water wasn’t able to push past it. Got it out then the pump worked fantastically. It shot coolant a good 3 feet so I had to shorten the pipe so that it didn’t go so far. The gear pump was fine. So I took it apart for nothing pretty much haha. Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 9, 2021 Share Posted March 9, 2021 Intermittents are terrible to troubleshoot; but lead to a lot of amusing stories... Link to comment Share on other sites More sharing options...
Justin Topp Posted March 10, 2021 Author Share Posted March 10, 2021 Now I’m having the issue of my hacksaw has terrible down feed pressure despite the valves being set to the max. Any ideas? Link to comment Share on other sites More sharing options...
Deimos Posted March 10, 2021 Share Posted March 10, 2021 hmmmm, the saws I worked with did not really have down feed pressure. The cylinder just acted as a counter to gravity. So gravity would pull on the saw which would drain fluid from the cylinder. Can you check what the state of the fluid in the cylinder is? And if you are able to drain the hydraulic fluid, if you leave all the hoses/pipes of the cylinder can you move the saw up and down without problems? What kind of valves are they? Link to comment Share on other sites More sharing options...
Justin Topp Posted March 10, 2021 Author Share Posted March 10, 2021 The fluid is new as of a two months ago the hydraulic system seems to work fine The valves it has look like needle valves. Link to comment Share on other sites More sharing options...
Deimos Posted March 11, 2021 Share Posted March 11, 2021 Is the system bled? Can you take tons of pictures of the cylinder, hoses/pipes, pump and the valves? Link to comment Share on other sites More sharing options...
Please sign in to comment
