Frosty Posted March 7, 2021 Share Posted March 7, 2021 I understood you Deimos, I only brought up the oxygen lance as an extreme example of applying heat to concrete. A little splatter from a torch or welder doesn't cause concrete to spall unless it builds up in one spot. Cut close enough the flame plays on it or lay a burning torch down and it'll rain hot concrete chips. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Cooterbobs.smelts Posted May 24, 2022 Share Posted May 24, 2022 On 3/1/2021 at 2:33 AM, George N. M. said: Do you remove the primers or are they too small to consider? Boy ow boy don't mess around with shells with primers. . I was distracting a hot 270 primer and it discharge into my finger..... I was so lucky that I was able to keep my finger.. If your going to be stupid you best be tuff hahah Just don't do it peeps Quote Link to comment Share on other sites More sharing options...
