BartW Posted February 15, 2021 Share Posted February 15, 2021 Hello All; These burners have really amazed me so far; and given how many of these I've traded / sold already, I think more people should know. Specs: 1" 316 stainless pipe (not in the picture is the 316 bell reducer from 1 1/2" to 1"). Pipe is about 10 inches long. The aluminium cast flare is bought of amazon (search for "Metre Star Inlet 1" BSP ") for about 20€'s shipped. The center rod is 1/4th BSP threaded 316 rod, with a 3 mm hole drilled through on a lathe. The tip has M6 thread to house the 1mm copper MIG-wire tip. The aluminium disk to reduce airflow is 4 mm thick, also threaded 1/4 BSP thread. The locking nut on top used to be a M12 nut; but I ran a 1/4th BSP tap through it. This burner is rock solid; will last multiple years; and allows fixed setups with copper pipes; but also flexible with normal gashose. I've had many people ask for the specs of this burner, and I'm not looking to go into the selling burners business; so here ya go Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted March 18, 2021 Share Posted March 18, 2021 So I sent away for the casting only; it is certainly worth its cost, but I will use smaller pipes and fittings then it is designed for. Quote Link to comment Share on other sites More sharing options...
