joecarter Posted February 1, 2021 Share Posted February 1, 2021 I just found a WQD Anvil. I'm trying to determine fair Market Value in order to sell. It's stone weight appears to be 0-3-3. The last 3 may be a 5? It weights approx. 93LBS. Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 1, 2021 Share Posted February 1, 2021 You selling it in Mexico or South Africa? Price depends a LOT on location. (This is the World Wide Web!) Anvils are cheaper in the UK than in Australia for instance; shoot just here in the USA anvils can differ by several hundred dollars depending on where it's located. I have a Ford car, I'm not going to tell you if it's been totaled in a wreck, has 250000 miles on it or is a mint condition shelby cobra with 200 miles. What is my car worth? Without details that question's answer is between US$200 to over a million dollars! Posting pictures of the face and side can help a lot! Somethings to watch out for: painting it or grinding or milling on the face generally make the price DROP substantially! Also someone welding up the edges because if it's not done right it means they will break worst than they were originally. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 1, 2021 Share Posted February 1, 2021 I would say the last digit in the weight would be a 5 making it 92 pounds when made. As Thomas said, condition & location are the main things in determining value. Link to comment Share on other sites More sharing options...
joecarter Posted February 1, 2021 Author Share Posted February 1, 2021 I'm in Columbia, SC. I have pictures. But what I find online hasn't helped me determine a price range. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 1, 2021 Share Posted February 1, 2021 We won't remember your location once leaving this post, hence the suggestion to edit your profile to show it. To add pictures you can drag the files to the paper clip at the bottom of the edit window and tell it to copy. Along with visible condition there is what is called a ring & rebound test. That will show if the hardened face of the anvil is becoming detached from the weld to the body, as in it has been through a fire or has been welded on and the HAZ is wide spread. I have seen anvils where the hardened face was completely missing or the face had been milled down so thin to make it look good but useless as a tool that the worth would only be scrap value, around here 20 cents a pound. Other anvils depending on use/abuse may go for US $2.00 up to $4.00 a pound. Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 1, 2021 Share Posted February 1, 2021 Now for local prices I would ask local smiths; have you contacted anybody at the Philip Simmons Artist Blacksmith Guild, https://www.philipsimmonsartistblacksmithguild.com/ The South Carolina ABANA affiliate? (Or you may be closer to a group in a neighboring state; folks are generally not fussy about what state you are living vs where you attend meetings...) Link to comment Share on other sites More sharing options...
Please sign in to comment
