natkova Posted January 7, 2021 Share Posted January 7, 2021 I will give it a try I dont know if it will be small or just what I want. I will do this experiment. It is around 20 inches on all side . 40cm that will be. Quote Link to comment Share on other sites More sharing options...
natkova Posted January 10, 2021 Author Share Posted January 10, 2021 Here it how it all looks. I need to seal it somehoe at top where smoke escape and if it was just a litle made taller but I didnt had materials for it. Quote Link to comment Share on other sites More sharing options...
aaamax Posted January 11, 2021 Share Posted January 11, 2021 what does it look like at the roof? interested to know how it works when you fire it up and if the pipe is wide enough for good suction. Have fun. Quote Link to comment Share on other sites More sharing options...
natkova Posted January 11, 2021 Author Share Posted January 11, 2021 It is not going to roof because iam afraid I could cause building to be set on fire I did it like this. To be honest its not best,.but its better than it.was. I was surprised because I didnt had leakage on sides, but.only on top of hood where it meet stove pipe. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 11, 2021 Share Posted January 11, 2021 That works; mine is similar: goes out a hole in the wall and up. Mine is a 25cm diameter pipe 10' long with no end cap. I think he wanted to know if there was an endcap or if it went high enough that things near it didn't interfere with the draft. I live in a desert and so not much rain to worry about. Quote Link to comment Share on other sites More sharing options...
natkova Posted January 11, 2021 Author Share Posted January 11, 2021 I have more pipes but I can risk to move chimney up to attic, there is a lot of wood there and are it can make a great fire. I have materials but I wont risk who know where spark can fly. This way I still can control sparks because I see my chimney. I think I will need something as aluminum tape to seal spots where smoke escape. But that is just at top where hood meet pipe. Quote Link to comment Share on other sites More sharing options...
Glenn Posted January 11, 2021 Share Posted January 11, 2021 Or cut thin metal and screw or pop rivet it as a patch where the smoke escapes. Quote Link to comment Share on other sites More sharing options...
natkova Posted January 11, 2021 Author Share Posted January 11, 2021 I did that and bend metal but it was in vain, You can see that part on picture and where smoke escape. It wasnt flat enaugh. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 11, 2021 Share Posted January 11, 2021 Aluminum tape will work, the hood shouldn't get very hot unless you build really large fires. I don't blame you for not wanting to run the stove pipe through the attic, I avoid risk with fire anywhere I can. You will need to run your stack above the roof once it's outside the building though. IIRC the number are 3' or 1m above the highest point of the roof within 3m. Don't quote me I may be off on the distances. The reason the top of the stove pipe needs to be away from the roof is to prevent turbulence caused by breezes blowing across the roof blowing smock back down the smoke stack. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted January 11, 2021 Author Share Posted January 11, 2021 12 minutes ago, Frosty said: Why it need to be that much high i mean higher than roof? Than i will need realy long pipe. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 11, 2021 Share Posted January 11, 2021 When wind blows over something like the roof it forms horizontal vortices on the down wind side just like water flowing over a rock or log in a stream. If the top of the stack is in or below the turbulence it will blow the smoke back down the stove pipe. This is why stove pipes and chimneys are all higher than the roof. Look around next time you go somewhere it should give you a good idea how high to make yours. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 11, 2021 Share Posted January 11, 2021 What about stuffing the leaky areas with aluminum foil? Quote Link to comment Share on other sites More sharing options...
natkova Posted January 11, 2021 Author Share Posted January 11, 2021 Well you have right even my chimney in house is over roof. Can cap help something becasue i have it. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 11, 2021 Share Posted January 11, 2021 I don't know how much a cap helps if any, I've never heard of an exception for the height rule for a cap though so I think not. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
bluerooster Posted March 18, 2021 Share Posted March 18, 2021 Two feet above ridge is code here. Quote Link to comment Share on other sites More sharing options...
