Power hammer build and effect of a larger anvil mass
There's a pretty inexpensive way to get your beam. Glue laminate it from ply wood. Cut 6" strips, use a good wood glue apply a THIN coat and screw on the next layer. You want the screw pattern pretty close, start in the center of each ply and work to the ends. I haven't made a beam or whatever more than 1 1/2" thick but it was very strong and stiffer than the ply wood I started with.
I wouldn't use epoxy or polyester (firberglass) resin I don't know how it'd stand up to repeated shock. Commercial Elmer's wood glue is plenty strong and has some flex.  Don't forget to (LIGHTLY) butter the layers so it penetrates the wood for a good bond.
  • Replies 80
Got the anvil mostly done. Just a bit more welding to do on it. I also sunk the base into the ground. Removed the pavers and sand. Than packed sand in to keep the base steady. And solid. It may rot out eventually but it should last a fairly long time. They are oak railroad bridge planks.
Still lots of work but I was able to test with just gravity. Hooked up a string to pull it up a bit and let it fall. 53 lb ram. If I can figure out how to upload to YouTube on mobile I’ll post a video. It rather impressed me. Can’t wait to get the motor on
I’ll add one. But die system is prone to change soon.
there is no motor. I have a rope tied to it that goes through a pulley on the roof. I pull down to lift than I drop the hammer. Letting gravity do the work. It will hit much much faster when there is a motor on. This was strictly a test.
On 1/10/2021 at 11:36 PM, Justin Topp said:
Would ply wood be best? I can easily get hickory, ash, Osage orange wood boards. Or any other wood really.
I know I’m a little late on this, but better late then never. Plywood would not be my first, or second choice in this application. Any hardwood would be good as long as it’s not one of the more brittle woods. Ash, oak, or hickory would all be good choices as long as they have straight grain.
Osage would be the best as it’s one of the strongest domestic hardwoods, but it doesn’t glue very well. Epoxy would be needed instead of glue. You also will probably end up breaking screws so thru bolts would be better.
With most other domestic hardwoods Titebond II would be a good option for glue. If you can get good clamping pressure fasteners aren’t really required, but I would put some 3/8”-1/2” thru bolts staggered off dented with at least a 1 1/4” edge distance. With hardwoods screws become more difficult and less effective.
Btw, I love your build. I can’t wait until you get it running and can see what it can do. Nice work.
Thanks for the info and your not too late for when I replace this beam eventually!  I was thinking plywood wouldn’t be great. I think gluing than putting bolts through the beam would be the best option if I laminate one Like you said. However I live in an abundance of ash trees. So I could probably mill one to size using a chainsaw.
That's very impressive, Justin. Now you've got me thinking about converting the nodding donkey to power (or at very least adding a bolt-on die to its underside). I think if I do, though, I'd probably include arftist's innovation of a flywheel between the motor and the cam mechanism, since that apparently does a good job of reducing the strain on the motor as it starts to transmit power to the hammer.
Collected the parts and did the finish machining myself. Very close to finishing the real cam and the hammer. Milled a keyway into the shaft. And turned everything else to size on the lathe. Tolerances are +/- 0.003”. Should work out pretty good I think.
  • 2 weeks later...
Please sign in to comment
