Pat Masterson Posted December 14, 2020 Share Posted December 14, 2020 Good morning - I was curious if anyone had a brand of fire brick to recommend for the bottom of my propane forge. I’ve had it about 8 months and it held up pretty well but then it in about the last month it’s become pretty bad. I can’t tell if it’s the brick itself that melted or if it’s from the work itself but it basically looks like a puddle of steel that hardens when the forge cools. When it’s hot I can feel the work sticking to it and some of it will actually come off and stick to the work. I will add pictures. But like I said it lasted pretty long then this seemed to come out of nowhere so I flipped the brick but now just after two sessions on the fresh side I can see the same thing starting to form. It’s the brick that came with this devil forge I bought. So is a better fire brick needed or is this going to happen regardless? Thanks. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 14, 2020 Share Posted December 14, 2020 Are you using any flux in the forge? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 14, 2020 Share Posted December 14, 2020 Fire bricks in a gas forge are considered consumables. If you are doing any forge welding it will accelerate the brick's deterioration. I would pick up some Kast-O-Lite30 and cast my own bricks. Quote Link to comment Share on other sites More sharing options...
Pat Masterson Posted December 16, 2020 Author Share Posted December 16, 2020 No flux but it has been up to forge welding heat quite a few times Quote Link to comment Share on other sites More sharing options...
