Justin Topp Posted December 12, 2020 Author Share Posted December 12, 2020 Yes it was Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted December 12, 2020 Share Posted December 12, 2020 Good Mourning, Bolt some supporting pieces underneath, keep it from breaking in two. Most heat goes up, but some goes down. Keep a layer of Clay or whatever to shield a lot of the heat from expanding the pan. If you try to braze it back together, you may make the problem worse. Neil Quote Link to comment Share on other sites More sharing options...
Justin Topp Posted December 12, 2020 Author Share Posted December 12, 2020 That’s what Is starting to seem like the best choice. I can always in bolt it if I need to. It’s a lot harder to un braze it Quote Link to comment Share on other sites More sharing options...
Justin Topp Posted December 14, 2020 Author Share Posted December 14, 2020 I bolted a plate on. Drilled the hole on one side of the crack 1/8 larger so it has a small amount of room to move. So that hopefully it doesn’t break somewhere else. But this keeps the gap mostly closed. Only opens a small amount when heated Quote Link to comment Share on other sites More sharing options...
anvil Posted December 14, 2020 Share Posted December 14, 2020 That's pretty strange that it cracked. Just checking. Did you use actual fire clay, or something else. How thick was the fire clay. Quote Link to comment Share on other sites More sharing options...
Justin Topp Posted December 14, 2020 Author Share Posted December 14, 2020 I used clay. Not sure the type. It was Over an inch thick Quote Link to comment Share on other sites More sharing options...
anvil Posted December 14, 2020 Share Posted December 14, 2020 I suspect you did not use fire clay. And it should have been thick enough to be at the bottom of low point of the forge sides. This is to keep long pieces from slumping and to give proper thickness for heat protection. I don't know but perhaps an inch of just plane clay may be harder on a cast forge than no clay at all. Quote Link to comment Share on other sites More sharing options...
Justin Topp Posted December 14, 2020 Author Share Posted December 14, 2020 It reached 90% of the way up. I’ve always been told any old clay works Quote Link to comment Share on other sites More sharing options...
