jlpservicesinc Posted August 5, 2021 Share Posted August 5, 2021 8 minutes ago, JHCC said: I’ve got some aluminum and foam metatarsal protectors I was hoping to sell at Quad-State; I’d be happy to send you a pair. I'd love that.. Link to comment Share on other sites More sharing options...
JHCC Posted August 5, 2021 Share Posted August 5, 2021 I’ll not to be able to get to them until the next time I unpack the shop, which might be a couple of days. Link to comment Share on other sites More sharing options...
Frazer Posted August 12, 2021 Author Share Posted August 12, 2021 A chipping hammer. Available at your local hardware store for ~$6, but who wants to do that. A few areas turned out a little funky, but it was a fun project incorporating several basic skills. Link to comment Share on other sites More sharing options...
Rojo Pedro Posted August 12, 2021 Share Posted August 12, 2021 Super nice! Link to comment Share on other sites More sharing options...
Frosty Posted August 13, 2021 Share Posted August 13, 2021 Pretty cool Frazer. How does it feel using? Frosty The Lucky. Link to comment Share on other sites More sharing options...
M.J.Lampert Posted August 13, 2021 Share Posted August 13, 2021 looks nice will try to share a pic of one my great-grandpa made he silver-soldered carbides on the tips M.J.Lampert Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 14, 2021 Share Posted August 14, 2021 That’s a pretty sweet looking chipper! Link to comment Share on other sites More sharing options...
Frazer Posted August 14, 2021 Author Share Posted August 14, 2021 Frosty, not bad. I like v2 better (even though the basket isn't as nice). The head was a little too long on the first one. M.J., please do. Mr. Willow/Rojo Pedro, gracias. Link to comment Share on other sites More sharing options...
Frosty Posted August 14, 2021 Share Posted August 14, 2021 Everybody should have a long range chipping hammer. I like the one on the right a little better too. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Frazer Posted August 14, 2021 Author Share Posted August 14, 2021 The real question is at what range does it become a driving hammer? The "prototype" can go in iron in the hat for this month. Link to comment Share on other sites More sharing options...
Frosty Posted August 14, 2021 Share Posted August 14, 2021 Good question. . . . I don't know, keep puttering around, you'll figure it out. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Frazer Posted August 14, 2021 Author Share Posted August 14, 2021 I'm still a little green to hazard definitive statements on the subject.. A little birdie tells me I'm not up to par. Link to comment Share on other sites More sharing options...
Frosty Posted August 15, 2021 Share Posted August 15, 2021 Aim at the birdies! Frosty The Lucky. Link to comment Share on other sites More sharing options...
M.J.Lampert Posted August 16, 2021 Share Posted August 16, 2021 here you go not the best pic but it sufices M.J.Lampert Link to comment Share on other sites More sharing options...
Frazer Posted August 25, 2021 Author Share Posted August 25, 2021 My first "full size" axe. I need to make a larger drift to clean up the eye and I'll probably even out the blade a little.. Then there is some profiling and a lot of grinding left to do. Still, it's getting there. The eye isn't as clean as I would like it to be on top, but I think I can fix that with the right size drift. Link to comment Share on other sites More sharing options...
M.J.Lampert Posted August 25, 2021 Share Posted August 25, 2021 not sure but there's either a lip or a delamination on the last photo showing otherwise looks great M.J.Lampert Link to comment Share on other sites More sharing options...
Latticino Posted August 25, 2021 Share Posted August 25, 2021 A good trick I learned from Jim Austin for the front of the eye is to use a round nose or half round chisel, like the one pictured below, to cut away the very front of the eye, removing any minor delaminations there. Cut in hot using a post vise to hold the stock works a treat. Of course that is just if the front of the eye is too tight or you have a cold shut to deal with. for an eye that is too wide at the front the easy solution is to forge it down further... Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 25, 2021 Share Posted August 25, 2021 Chainsaw file to clean up after chiseling. Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 26, 2021 Share Posted August 26, 2021 when you make the mandrel.. Just massage it in. You can do this before the steel is welded into the cutting edge so there is no worry of over heating the steel in the cutting edge.. If massaged in around the mandrel at the welding heat, the seam there will weld up just fine and really if done will not have a weld seem at all. This is the method I use and if I can do it.. Anyone can.. Nice preform work and weld.. depending on what you are after.. I often will use a commercial handle as it saves me the time having to completely make 1.. Are they good.. No.. But if I sell and axe than the person who buys it can simply replace it vs sending it back for a handle job.. So the eyes are shaped to receive these commercial handles as is the mandrel. Link to comment Share on other sites More sharing options...
Frazer Posted August 26, 2021 Author Share Posted August 26, 2021 M.J., nope, no delamination. To be honest I am somewhat surprised by that. That was a lot of material to get up to a welding heat and flipping an axe that is ~4.25" wide really disturbs the fire. The eye still isn't perfect on top (right image), but I think it's good enough for me to go in and clean it up with a file. Latticino, That's a good suggestion. I'll put that in my memory banks for the inevitable day where I run into issues. I think I had a lot of beginners luck on this one. Your tip to go back and fuller the set downs that make up the eye was HUGE. That nice shoulder made things so much cleaner. Jennifer, the eye is made to fit a commercial handle for a 2.5# axe head. I don't mind making small handles, but for a larger one like this I think a standard size eye is the way to go. Sooo, my original plan was to grind this down to the weight my coworker was looking for... but I've kind of grown attached to it.. I think I'm going to leave it where it is (~2.5#'s) and keep it as an axe. I started a smaller version today. I mean, I have make sure it wasn't just beginners luck right? Link to comment Share on other sites More sharing options...
M.J.Lampert Posted August 26, 2021 Share Posted August 26, 2021 ok giver on part 2 M.J.Lampert Link to comment Share on other sites More sharing options...
Frazer Posted August 27, 2021 Author Share Posted August 27, 2021 Done. Final weight of the head is 2lbs 5 oz. Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 27, 2021 Share Posted August 27, 2021 Looks great from the side.. How's about a good one from the top and bottom so can see the weld seam Link to comment Share on other sites More sharing options...
Frazer Posted August 27, 2021 Author Share Posted August 27, 2021 I don't have a smartphone so the image quality isn't great. Regardless: Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 27, 2021 Share Posted August 27, 2021 Looks great.. For myself I'm not usually to interested in what the axes look like from the side. I mean a few shots is good, unless there is something interesting.. Love how it came out. The weld seams are what interest me the most. Looks great and a mighty fine chopper.. Your buddy is very lucky.. Be sure to put your makers mark in it and a date if you can.. 30 years or 40 years from now those people will wonder who made such a wonderful tool. Thanks for posting up the extra photos.. Very well done.. Link to comment Share on other sites More sharing options...
Please sign in to comment
