Killerace Posted September 27, 2020 Share Posted September 27, 2020 Do I need rigidzer I put kastolite 30 on? If so how much will a pint cover? Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted September 28, 2020 Share Posted September 28, 2020 You put rigidizer on the insulation before putting on the Kast-o-lite 30 on. The coverage depends upon the size of the forge and how many layers of Kaowool. Link to comment Share on other sites More sharing options...
Killerace Posted September 28, 2020 Author Share Posted September 28, 2020 No offense intended but I don't think that's how that works a pint is a pint doesn't matter how big your Forge is. Link to comment Share on other sites More sharing options...
Jealdi Posted September 28, 2020 Share Posted September 28, 2020 The rigidizer you can buy here on IFI should cover 6.26 square feet per pint according to the post by Glenn. As for any other rigidizer, without knowing what you are using, we do cannot really tell you how much it will cover. Link to comment Share on other sites More sharing options...
Killerace Posted September 28, 2020 Author Share Posted September 28, 2020 Okay thank you I must have missed that part. Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 28, 2020 Share Posted September 28, 2020 And if the fiber is already covered then you don't put rigidizer on the rigid cover. You can save it for your next reline---forge linings is like car tires: they both need to be replaced with use. Better tires, better lining jobs last longer---as long as there are not accidents to them! Link to comment Share on other sites More sharing options...
Please sign in to comment
