adamt Posted September 7, 2020 Share Posted September 7, 2020 i took a power pole and built a spinning teeter totter for my kids, i used a 3/4" hard steel rod for a center pivot rod, but it broke due to the teetering and the tottering, obviously the spinning was not a stress on it. I would like a larger diameter rod and one that wouldn't snap, so it needs to be springy---- what should i look for. I would reuse or salvage something if i had an idea where to look, or i would buy a new chunk of steel if i was sure what to get. i need something with plenty of spring, maybe an inch in diameter and 24" long. what would i buy? Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 7, 2020 Share Posted September 7, 2020 Welcome aboard Adam, glad to have you. Just out of curiosity are you interested in blacksmithing or just need a little engineering help? Oh, we'll do what we can to help but I was wondering. Were I building one and had to use a power pole, (NOT CREOSOTED I hope!) I'd mount it on a truck front spindle and use the hub to bolt to the foundation. The spindle would bolt to the timber's center of gravity so it could teeter with limit stops so no little feet would get crushed. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
adamt Posted September 8, 2020 Author Share Posted September 8, 2020 frosty--- i have lurked for years, i just never needed to ask a question.. i do a limited amount of black smithing and blade smithing. i farm for a living, so it's more of necessity sometimes rather than a hobby lol Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 8, 2020 Share Posted September 8, 2020 Heh, heh, heh, we'll have to give you a code name hmmmm . . . Deep lurk! You're probably about as traditional a blacksmith as in the forum. What do you farm? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted September 8, 2020 Share Posted September 8, 2020 I wouldn't use a rod. Make a pivot point and mount it to a swivel base. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 8, 2020 Share Posted September 8, 2020 Getting a 1" rod to be "springy" ight be a tad difficult; can you separate the pivoting and springing part---maybe make the pivot out of caraxle and the spring out of car coil spring? (don't weld on the spring---make a mechanical connection!) Quote Link to comment Share on other sites More sharing options...
Welshj Posted September 13, 2020 Share Posted September 13, 2020 Where are you from Adam? Quote Link to comment Share on other sites More sharing options...
