8 hours ago, ThomasPowers said:
Can you mount it on the bottom of the top instead of the top?  That should get you an inch or two.
I'm not rushing to get it mounted as I'm just using my garage as a temporary forge.
Hopefully by this time next week this concrete base will have walls and a roof:
Once that's sorted, I'll get things better situated.
  • Replies 26.3k
  • JHCC
    3135
  • ThomasPowers
    1935
  • Frosty
    1645
  • Daswulf
    1642
23 hours ago, Daswulf said:
 Ben, Nice work, what steel did you use? I keep thinking they need to be made of higher carbon steel but that might just be a misconception I have.
I used a piece of coil spring, I had the same worry about what steel to use. It got tested few times last night and it survived intact.
I was thinking about the stainless hammers. I'm not sure there is a point in passivizing them really. Ya'll have been saying, you got to be sure not to use abrasives that have been used on steel because it will transfer onto the stainless steel and will cause it to rust, but, that also I would think would mean that when you have it laying on your anvil that it would be "contaminated" and would make the passivizing pointless. Now, I may passivate it just because, but, I was just thinking about that. What do ya'll think??
        Littleblacksmith
        Littleblacksmith
You are correct.. any carbon steels will transfer.. chemical passivation i's the easy way to do it but you can also grind then use buffing wheels with fine abrasives..
I've done stainless steel weldaments and as long as you get all the big cracks off and give it a full polish it will take a long time for it to rust..
so, are you saying that I should passivate it? I will only be grinding the faces, though will be using a scotch brite on the rest of the hammer. Don't have any cracks in it....
        Littleblacksmith
Tried out the stake anvil tonight ( I love it)!even with a few misstrikes it held up. It's mounted too high in my shop abuse stump that I did some forming in.
The ring around where the shaft goes through makes no difference. I hammered like heck on it and it held up great. Only a "thunk, thunk,thunk.,.. Really cool and different. Next is to find a stump the correct height. It is proofed in my opinion and the testing will continue.
        Littleblacksmith
Ideally all the scale needs to be removed..  if you are happy with the finish the scotch Brite leaves then good enough...  passivation is used primarily on smoother finished items to remove the iron carbon matrix and leave a chromium surface exposed.
In other words it's not usually used on roughly finished items..  only polished to highly polished..
So the question becomes how finely finished do you want it to be?
It's been a long time but there are products sold that will remove the scaled surface and leaves a matt under layer perfect for polishing.
Ok. Then looks like I may not passivate it as it sounds almost pointless, as I would prefer it to still look forged and not machined, so I wont be doing any serious grinding and polishing to it.
Das-Nice stake anvil!! so, did yo forge weld that stake in there? I know you riveted it on (if I remember correctly), but also remember you saying that you did some welding. Or did you electrically weld it in? you had said that you had thought about making one out of RR track, I have forged one out of the flange before. Really simple to do, a much smaller one though. the one I did, I quenched in water, will never do that again! left some 2" or so long cracks in it! I still use it, lasted about a year, and then a couple months ago the tip of the horn fell off. It was a laughing crying moment, I couldn't get over how funny it was, but also it really stank that I just broke the horn off an anvil (sounds pretty bad when I put it that way....). I need to make a new one, I mostly just used it for the horn for shaping key rings on.
        Littleblacksmith
The only way to leave it as forged perfect is to use perfectly smooth tooling and then do an acid bath and then for the maximum protection, passivization..   smoothness of the surface is the key to rust resistance in stainless.. smoothness at a microscopic level and this is where passivization shines..  Nearly all Stainless steel processed is passivized as the last finish process..
Like i said before it's been years since I looked into it and I used a spacial compound for cleaning food grade stainless steel weldaments..  It was really bad stuff..
you can try high strength vinegar to get rid of the scale.. It will be a slow process but it could offer decent results but at some point you will still need to polish it..  This is where having a passivization tank can make a world of difference..
I made this from an old rr hammer and torsion bar from a truck. Both sparked high carbon. I did do some MIG welding and tried some TIG welding on the face but I probably would have had the same results without welding on the face. It turned out great and "feels" as hard as my other anvils under the hammer.
Thanks  Stitch. You can lift camp oven lids with a bit of fence wire or a tent peg, but these lifters do sell well. They are popular with caravanners and campers and I think people like the Outback style of them. I like them for demos too, because there is a variety of processes involved.
Made a fullering tool today using bits and pieces I had sitting about.
Rough and ready, but it worked ok on a test piece.
Going to have to hunt for some springs for the sides so it pops back up. All I had was some valve springs but they were too big and a bit too stiff for this purpose.
Also bent a bit of round bar to replace the broken u bolt from the leg vice. Now I need to track down a suitably sized die to cut the threads.
Not very exciting, but somewhat productive.
