ThomasPowers Posted August 22, 2021 Share Posted August 22, 2021 I can't see my staples even with a mirror; makes it hard to do self removal. Now that my wife knows what they look like I expect she will be able to remove them. Quote Link to comment Share on other sites More sharing options...
Ted Ewert Posted August 23, 2021 Share Posted August 23, 2021 The wife wanted a pair of large leaf hooks for a charity auction she's involved with. These are made from 1/2" × 1" bar. Hooks are 2" dia. The piston in my hammer cylinder decided to part company with the shaft during operations. Surprisingly there was little internal damage. Reattached it with some locktite on the bolt and it works fine. Cheap Chinese parts aren't worth the initial savings. Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 23, 2021 Share Posted August 23, 2021 Half chisel, half fuller sounds like a slick tool Bob and made for radiusing the bottom of chisel cuts. Cool, I think I'll have to make one. I like your frame Pat, it came out nicely. However, if the gap in the corner bothers you enough, turn the frame over and use it as a place to start one of the vines. Vines grow out of cracks you know. Another thought would be have the stem rooting in the crack but that'd be a more advanced technique on that scale. Still. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Rojo Pedro Posted August 23, 2021 Share Posted August 23, 2021 Real nice Ted. I like the length of the hooks My lady always wants more S hooks so I tried to make 3 identical ones from some 1/4” garage door spring. Turned out pretty close but it was harder than I thought. Couple fun hours for sure thanks for lokking Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 23, 2021 Share Posted August 23, 2021 Looking good Ted, they're getting better just wait till you've made 100. People will be begging you to make sets. KA CHING! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 23, 2021 Share Posted August 23, 2021 Make a group of S hooks at 3 different lengths. Also make S, C, and J hooks and have her choose which ones she wants. Be ready to have her take the whole batch so she can have them on hand when she wants one. She will soon find that she can use multiple hooks on the same plant to adjust the height to exactly what she wants. Do not show her that you can put a leaf on the end of the S hook instead of a pig tail. That will be a whole different request for a quantity of the hooks. They make 1/4 inch round bar in 20 foot lengths, get several. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 23, 2021 Share Posted August 23, 2021 Ted Beautiful work.. Wonderful finish and detail.. Rodro Pedro.. Those are mighty fine and very hard to do well, especially out of spring.. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 23, 2021 Share Posted August 23, 2021 1/4" sq stock hot rolled if you can find it and cold rolled if you can't is one of the fastest ways between a forge and money. Lots of things you can do with it and it's fast to forge due to the size. Much faster than working spring! Quote Link to comment Share on other sites More sharing options...
BillyBones Posted August 23, 2021 Share Posted August 23, 2021 My dad was working on his car one day and nicked his hand. Seeing as to how he id diabetic, on blood thinners, etc. he went to take care of it and bandaged it up. Next morning he woke to a bed full of blood so off to the doctor he went. Doctor said no problem a stitch should fix it, no well 2 will do the job, no lets try 3 (keep in mind in is a small nick) long story short half a spool of thread later and it is stopped. When he went to get the stitches out it took the doctor almost and hour to work them all out. Thomas, at least with the wife doing it you will be able to keep the staples for that special blade. Hot and humid this weekend so mostly a lot of sitting in the shade. Got some forge time mostly trying different ways to make a big nut. But did get some work on my railing done. The big nut will replace the one on top to match the other bolts for the brackets. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 23, 2021 Share Posted August 23, 2021 3 minutes ago, ThomasPowers said: 1/4" sq stock […] is one of the fastest ways between a forge and money. It’s also pretty easy to cut or fold into shorter lengths to fit into a smaller vehicle! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 23, 2021 Share Posted August 23, 2021 A "Wrest" will break it off nicely (for example take two large adjustable wrenches and place then at 90deg to each other and almost touching and then apply lots of pressure to shear the 1/4" sq stock. I've seen large nuts made by bending sq stock around and forge welding it, then forging the outside square using a mandrel on the inside to make drilling and tapping it easy. You can see some like that in thenold mine hardware and see the forge weld lap after 100 years of exposure. Bad electrical storm last night; a lot of the town had a long power outage; I doubt any work gets done on my shop's electrical system this week! Out where we were at we were fine didn't even have to reset the clocks and had a great view of the "fireworks". Quote Link to comment Share on other sites More sharing options...
Gandalfgreen Posted August 23, 2021 Share Posted August 23, 2021 Well this stinks. Got my forge finally started mixed my silica coated my forge go to light it for first time get it lit goes out so turn high pressure regulator valve to off position and the valve strips out and wont turn off. Run to the 3 local stores to hopefully find a new highpressure hose and no luck. Anyone reccomend a brand i can order online before i search amazon. Hope this does not ruin my silica phase not being able to fire now. Without bad luck i have no luck lol. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 23, 2021 Share Posted August 23, 2021 Worst case scenario, you can set the rigidizer with a plumber's propane torch. Just go over it bit by bit, heating each section to glowing before you move on. It may take a little while, but that will enable you to put in the hard refractory lining and give it plenty of time to cure while you're getting your burner's propane supply worked out. Quote Link to comment Share on other sites More sharing options...
Gandalfgreen Posted August 23, 2021 Share Posted August 23, 2021 Right now only got MAP will have to go to store just worried if i will be able to reach all spots guess we will find out. Had to take a break needed mental break. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 23, 2021 Share Posted August 23, 2021 Knowing when to take a mental break is one of the most valuable skills one can have, right up there with keeping hydrated. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 23, 2021 Share Posted August 23, 2021 Not in the shop; but my Dr's office called and told me my staples had been in long enough, (too long), come in immediately for removal. (Helps that my Dr's nurse is my next door neighbor...) Less than 30 minutes to drive up there, sign in, get them removed and back into work! Yes I have them (and the removal tool!) Some of the more expensive steel I have bought! Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 23, 2021 Share Posted August 23, 2021 3 hours ago, Gandalfgreen said: so turn high pressure regulator valve to off position and the valve strips Which knob were you turning? Regulators are NOT valves, the regulate pressure they are NOT designed to open and close circuits like the: Tank valve a ball or gate valve. You probably screwed the adjustment screw out of the screw box. Never NEVER use the regulator as a valve unless it's a dire emergency, even then it's a bad choice. Search "Propane Warehouse" select "regulators" on their site, the 1-30 psi is $42. Farther down the page is a propane gauge $15. There is more hose than a crazy person needs. Get a 1/4 turn propane shut off valve that will screw directly into the output side of the regulator and then to the hose for lighting and shutting down the fire. The tank valve is then used to close the tank, the regulator will depressurize itself safely, they're designed to and if the hose isn't under pressure there will only be what's under the diaphram and in the regulator to bleed off. Yes it's going to cost a few bucks but it's better to do some things right rather than cheap. A propane leak or failure can ruin everything close. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Gandalfgreen Posted August 23, 2021 Share Posted August 23, 2021 Frosty the regulator knob on my hose for pressure. Not the tank knob. This piece o junk in picture below. Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 23, 2021 Share Posted August 23, 2021 That is NOT a valve, it's a pressure control. Just because you can turn the regulator so it seems to be off doesn't mean it is. At least it was a cheap lesson compared to what a propane leak can teach. Check out Propane Warehouse, they have everything you need to do it right and the prices are reasonable. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Gandalfgreen Posted August 23, 2021 Share Posted August 23, 2021 Well thanks sir. Just finished using torch and hope i did it right. Started out blue 2 hours later not blue and all dry hope i got hot enough. Quote Link to comment Share on other sites More sharing options...
Rojo Pedro Posted August 24, 2021 Share Posted August 24, 2021 Look for a turkey fryer regulator. They are 20-30 psi Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 24, 2021 Share Posted August 24, 2021 I once picked up a turkey fryer for US$3 as the guy had let the hose drag off the side of his trailer while taking it to the fleamarket and it had worn the brass fitting to the propane tank down...took it home and swapped out a brass fitting from a free junked propane grill and used it for another 10 years. Before junking the non-working one; I'd take it to my favorite propane dealer and ask if it could be fixed or was worth trying to fix. Most of the time they would do a simple fix for free as I buy all my forge stuff from them and will bring a bottle opener by every now and then... Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 24, 2021 Share Posted August 24, 2021 I would definitely recommend a hose with a pressure control, a gauge, and a braided cover on the hose, like this one: The gauge helps you keep an eye on how much fuel you're putting into the forge, and the braided cover helps protect the hose from errant hot things. As Frosty says, adding a quarter-turn shutoff valve is a really good idea. At very least, make sure you turn off the valve at the tank when you shut down. Quote Link to comment Share on other sites More sharing options...
Donal Harris Posted August 24, 2021 Share Posted August 24, 2021 On 8/23/2021 at 11:08 AM, JHCC said: It’s also pretty easy to cut or fold into shorter lengths to fit into a smaller vehicle! I used to do that, but a few months ago Home Depot had a sale on Ryobi batteries. Buy two and get a free cordless tool. I needed the batteries, so I bought a couple. For the free tool, I chose a 4.5” angle grinder. Not useful if you need to do a lot of grinding, but is great for making a few quick cuts. Especially on small stock. Quote Link to comment Share on other sites More sharing options...
Jobtiel1 Posted August 24, 2021 Share Posted August 24, 2021 Finished the forging on the little camp axe today. It was quite challenging getting the forge weld for the bit. I welded in a piece of file I had laying around. Wanted coil spring for the bit, but I ended up chiseling the split to deep. I'm quite proud of the forge weld, even though I burnt the piece a bit, it's my second forge weld ever. The chisel split and the preform before welding. the finished forging after forge welding (and burning a piece from the front, and cutting the burnt piece off.) Now it's time for a little file work. ~Jobtiel Quote Link to comment Share on other sites More sharing options...
