jlpservicesinc Posted February 4, 2020 Share Posted February 4, 2020 Goods, Nice.. Have I missed the photo's of your wrought iron beauties? I wanted a 4.5lbs steeled wrought iron to go with the 2.75lbs and used 1.125sg X 4 bars x 4" to get to near the 4.5lbs mark.. Batch of bad coal had me on the ropes first few welding heats. here it is.. I can't decide what shape I want it to be, so have left it rough forged. The face of the 2.75lbs steele wrought hammer is just a tad larger on the corners than I'd like for a general forging hammer. The outside corners get in the way some. Hard to believe its' been sitting in this state of finish since 9/2018. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 4, 2020 Share Posted February 4, 2020 2 hours ago, jlpservicesinc said: One persons fool is another persons Genius.. Jennifer P.. ”It's such a fine line between stupid, and clever.” — David St. Hubbins Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 4, 2020 Share Posted February 4, 2020 Every time we try and idiot proof something, they come up with a new & improved idiot. Quote Link to comment Share on other sites More sharing options...
Goods Posted February 4, 2020 Share Posted February 4, 2020 Pedro, still need to sharpen it. I’m going to take it to a hammer-in Saturday and talk it over with some folks before I make my final decision on slitter vs slot punch. JLP, I first posted about my only previous wrought iron hammer on page 361 of this topic, but never posted a finished product. So here it is, not as pretty now that it’s been heavily used and weathered. (Very leaky garage that is not the best shop...) I’ve become quite fond of this hammer. Very flat face and light weight works well for setting welds, the small pein move material fast, and the store bought handle is comfortable. Most of all I made it! David Quote Link to comment Share on other sites More sharing options...
GolFisHunt Posted February 4, 2020 Share Posted February 4, 2020 My shop time today was mostly spent abusing wood on my lathe. A gentleman recently asked if I'd be willing to make a copy of one of my shaving brushes. I obliged, but it has been several years since I've done any turning where details mattered. Time for some practice. The random piece of walnut selected ended up being an overly fancy file handle. Next I turned a shaving brush for myself for more practice and filed on a knife in between coats of finish. Fun day! Quote Link to comment Share on other sites More sharing options...
Les L Posted February 4, 2020 Share Posted February 4, 2020 Golfishunt, beautiful wood work and a good looking knife. One thing I would do different with your backing board is trim the end of the board to match the curve of the blade point to keep the file from hitting the wood and messing up my bevel. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted February 4, 2020 Share Posted February 4, 2020 Goods, you did a really nice job... I can't use a hammer with a face that flat.. Never have been able to. I like the design.. it's a soft swedish design and like it a bunch.. Well done.. Was fun to build right. I love work like this.. The largest factor that I see with this kind of construction all the time is people think the face plates were thick for hammers.. they were not.. There is a ratio of square inches to face thickness and if gone over the faces usually peel off.. My currect hammer in build might suffer this very problem.. I wanted to have the hammer at 4.5lbs so added a little extra face material.. What I should have done is welded on another section of wrought iron and then faced it.. Very nice. it must swing great. Les, you are correct it is easier to, but not really much of a problem.. Just slide the knife down.. Or angle it so you are not catching the wood.. Most people don't really know how to use a filing board.. A file should cut without pressure and just letting the file cut should do the work.. This will not bend the blade unless it is a very thin blade like a filet knife.. Most also don't realize when they indeed do have a dull file since they are used to pushing harder.. This will bend the blade for sure.. If one is making the same knife pattern over and over again, then it's a great idea to make a board to fit it.. But for general knife work a rounded end board works and personally I just leave it square.. This way I can pull the blade over and use that corner to good advantage. All the knife videos I use a filing board.. Use the same board in fact for all knives.. In the trailer there is not much room so have to watch direction and such of the file so I don't smash my hand into something. but overall it works.. I use the same board for all in the trailer.. Also just use a clamp. My file board is nearly 2 inches wide and about 6" tall white oak. Quote Link to comment Share on other sites More sharing options...
Marcus_Aurelius Posted February 4, 2020 Share Posted February 4, 2020 Took some time in the shop last weekend to forge out a present for a friend who recently celebrated his birthday. The leaf was supposed to be a keychain but I ended up getting ahead of myself and forging it from 3/4 round. It’s a around 8 inches long, so more along the lines of a wall decoration. I’m happy with the design but I need to work on cleaning up the decorations on the leaf especially the fuller marks on the sides. - Mark Quote Link to comment Share on other sites More sharing options...
CrazyGoatLady Posted February 4, 2020 Share Posted February 4, 2020 Goods, that's a great looking hammer. It does look like it wants to swing! GFH, beautiful woodwork. Jennifer, thanks for more tips on filling. I've learned more about filing the last couple of months or so than I ever knew before. It's an art in itself and I never really thought of it that way. Marcus, I like you leaf. The stem portion looks nice and smooth. Sometimes I like them to look viney, but I get so carried away with planishing on nearly all my work to remove all the facets I can that most are smooth as butter Good job Quote Link to comment Share on other sites More sharing options...
Shabumi Posted February 4, 2020 Share Posted February 4, 2020 19 hours ago, ThomasPowers said: It's not the hearing but the feeling! That concert must have been something to experience. This is an interesting idea for chimes, really large so you could feel the vibration as it rings. I have some 3inch pipe I could play with. 18 hours ago, CrazyGoatLady said: We are getting ready for a new batch of chickens That should be fun, I love having chicks around. We started with 100 3 years ago, and we're down to about 80 right now. This spring were going to get the new batch and retire the old ones. What breed do you use? We use Rhode Island reds, barred rocks and the cross between those two, black star links. Everyone else, those hammers, handles, knives and leaf look really good. Don't worry about the fullering too much, you'll never find a perfect leaf, or every leaf you find is perfect. Take your pick Quote Link to comment Share on other sites More sharing options...
GolFisHunt Posted February 4, 2020 Share Posted February 4, 2020 Les, good tip, thanks. Jennifer, I see your point on the filing block and several of my files are quite dull. Future cutting edge stock or hot filing work. CGL, thanks! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 4, 2020 Share Posted February 4, 2020 As scale is hard on files you can make you new sharp ones last longer by removing it with old files or chemically (soak overnight in vinegar), or sand blast, or... Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted February 4, 2020 Share Posted February 4, 2020 vinegar is super handy especially if you have a few knives forged.. Leave in to pickle and when ready good to go. I use old horse rasps to remove the scale and don't care much how fast I go thru them.. I must have 30 used ones.. I just used to throw them in the recycle bin but now they go to other homes as needed. Quote Link to comment Share on other sites More sharing options...
BillyBones Posted February 4, 2020 Share Posted February 4, 2020 Got a job offer from Alro steel, who just so happens to be where i buy my steel from. Hope they give employee discounts. I am kind of excited about this. Quote Link to comment Share on other sites More sharing options...
CtG Posted February 4, 2020 Share Posted February 4, 2020 Nice! Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted February 4, 2020 Share Posted February 4, 2020 Billy, that is very exciting.. I've hear of Arlo steels all the way up here.. Good source for tool steels IIRC.. Fingers crossed. Quote Link to comment Share on other sites More sharing options...
BillyBones Posted February 4, 2020 Share Posted February 4, 2020 Thanks, they are looking for people pretty hard right now. The job market here is wide open, every where is hiring. I been wanting to get away from automotive work for a while now. I used to love it now it is a chore to get up and go to work everyday. Quote Link to comment Share on other sites More sharing options...
CrazyGoatLady Posted February 4, 2020 Share Posted February 4, 2020 2 hours ago, Shabumi said: What breed do you use? Buff Orpingtons currently and adding more. Getting some brown sexlinks and some production reds for my FIL. Oh, and a few transylvanian naked necks. I love my chickens also. Oh and we will get cornish crosses soon as well Billy, congrats on the job offer. Hope you get it! Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted February 4, 2020 Share Posted February 4, 2020 I got some isa browns last year and I think they are the best laying chickens I ever had. I don't think they have missed a day this winter. the girls just had to have a duck so I wound up with a green headed male, a pekin and a runner. That runner lays as well as any chicken I ever had. A huge delicious egg. I'm thinking about some more of those. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 4, 2020 Share Posted February 4, 2020 Runners are the geekiest of ducks. Quote Link to comment Share on other sites More sharing options...
BillyBones Posted February 4, 2020 Share Posted February 4, 2020 18 minutes ago, CrazyGoatLady said: transylvanian naked necks Had to look that up. Them there are some ugly chickens, almost as bad as those hairless cats, nice target zone for the hatchet though. In my world there is only 3 breeds of chicken...Baked, fried, and bar-b-q. Word of warning to any one looking them up...Turn on your safe search. I got a bunch of pics that have nothing to do with chickens, poultry, or birds at all. Definitely not family nor work safe. Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted February 4, 2020 Share Posted February 4, 2020 6 minutes ago, JHCC said: Runners are the geekiest of ducks. They are so funny to watch. They really are great layers though. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 4, 2020 Share Posted February 4, 2020 CGL: A bit late looking up the LOGOs but the first one is the Alaska Seawolves, done in the Hyda style, the second is another later version, not so easy to use for a finial though I like it a lot. The one we're seeing on TV right now is sort of a blend of the two but I didn't see it when I searched. There are LOTS of Seawolves logos out there, seems Alaska isn't the only place likes the name. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Shabumi Posted February 4, 2020 Share Posted February 4, 2020 Buffs are great. Big eggs, with a good chance for multiple yolks as they get older, though not as rich as a duck egg. I think our record was a 4 yolker from the buffs we had. Some of my favorite breeds are the Picatas and Cacciatores Frosty: the SeaWolves look way more menacing than the Miners of our local HS. Quote Link to comment Share on other sites More sharing options...
CrazyGoatLady Posted February 5, 2020 Share Posted February 5, 2020 The naked necks are not blessed with good looks for sure! Researching them, as far as anyone knows, they were the original meat bird and bred for flavor... Not sure how that works We are only getting a few to start and see about them. Shabumi wow...a four yolker. I've never seen that happen. I've found a lot of double yolks, but we sell most of the eggs so I have no idea how common it is. I can't eat eggs. Allergic to them except for cooked in things. I'm also lactose intolerant... and I live on a farm. Talk about irony. I can handle small amounts, I just have to watch it. Frosty, thanks for the references. I'm sketching out different designs and I'll add that to the list. I just got to thinking, you see horse heads done a lot, so why not other animals also? I figure I could make about any animal I wanted to. Quote Link to comment Share on other sites More sharing options...
