jlpservicesinc Posted August 22, 2018 Share Posted August 22, 2018 2 hours ago, Frosty said: Jennifer: (I REALLY need to write your name somewhere I can never remember how many ns) I love my slab handles but they're straight tapers and pretty stiff. 2 N's.. I adapted a handle style years ago and it has been my go to ever since.. I do have a few straight tapered but slabbish handles on my vintage straight and cross peens and like them for what they are.. This particular handle is the same pattern I always use, just octagonal instead of ovalish.. I wanted a handle that would lock into my hands more so the octagonal shape.. But if I don't like it in a week or 2 I can just remove the corners and it will be exactly the same as my other hammers.. Same shape, length and profile.. All my main forging hammers have the same handle.. it might be a farrier thing, but the handle shape was in use 3 years before I became a farrier.. LOL.. Maybe I was a farrier before I was a farrier.. I find more serious farriers use a hammer that has very little necking down.. Usually very straight in fact.. The nail driving handles usually have more shape to them.. Might be more slabbish.. The farriers I have seen work do have a tendency to be a little thinner than I like.. I like a handle to fill my hand.. The throat or neck of this hammer might look pretty thin but it's because of the head and I don't like to have an abrupt transition from handle to head.. I like the transition to be almost non existent.. I own and use other square faced hammers.. But for the weight the face is pretty large.. 2.75lbs with a 1.750 X 1.625 face.. The face isn't completely flat and found it was great to swing with little edge denting or problems related to the square face.. Where I will run into problems is when it comes time to forge a triangle as I do this on the flat of the anvil verses over the edge.. the necked down section is probably about 3/4" or 7/8" .. There are more pic's with more info on the hammer thread.. https://www.iforgeiron.com/topic/59626-wrought-iron-hammer-build-old-school/ Link to comment Share on other sites More sharing options...
Daswulf Posted August 22, 2018 Share Posted August 22, 2018 I picked up the HF deadman switch and the on off foot pedal switch when i was still experimenting with how I wanted to operate my forge. The router variable speed with on off won out for what I do, and with my forge, so the others are hanging out for another use. They were not expensive for me at the time so I didnt mind spending the money. Link to comment Share on other sites More sharing options...
Reeltree Posted August 22, 2018 Share Posted August 22, 2018 Thx Mr. Olsen,, it wore me out for sure. The # 12 Peddinghaus is nice only issue is the recess cut around the outer edge of the hardy hole,,can't really get a good shoulder set in Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 22, 2018 Share Posted August 22, 2018 45 minutes ago, Reeltree said: Thx Mr. Olsen,, it wore me out for sure. The # 12 Peddinghaus is nice only issue is the recess cut around the outer edge of the hardy hole,,can't really get a good shoulder set in What a bogus thing they did with that chamfer.. Wish they would just leave them flat.. Link to comment Share on other sites More sharing options...
Reeltree Posted August 22, 2018 Share Posted August 22, 2018 Yep,,got that right Link to comment Share on other sites More sharing options...
Hans Richter Posted August 22, 2018 Share Posted August 22, 2018 Build a new pedestal from some scrap metal to put a ventilator/blower right under my shop roof and behind the forges. In earlier days, he stands on a shelf attached to the hard shop wall. After adding the extra noise insulation with foam mats not possible anymore. Carried out also some measurements by test running the new bigger gas forge regarding: -heat up time tiles and ceramic beaded blanket 20 minutes -maximum temperature at the exhaust after 20 minutes at 1835ºF -heat up time ½ in mild steel square stock in running forge till orange red < 3 minutes -CO-pollution to room <40 ppm -heat radiation to wall and roof -acceptable (touchable) -determine set up parameter pressure propane and pressurized air After all, very satisfied with the result and the intended swirl and heat spreading in the forge camber at a low dragon breath. Get lately more and more questions of students and starting smith brothers to assist/teach them how to build their own equipment without to have to rely on suspicious building instructions on YT. Till now I always refer to IFI, but for many applicant is English not his mother tong. Cheers, Hans Link to comment Share on other sites More sharing options...
Daswulf Posted August 22, 2018 Share Posted August 22, 2018 Keep up the good work of teaching and working Hans. There is a lot of bad info out there to counter. There has to be an app or something to translate web pages. Link to comment Share on other sites More sharing options...
Ted Ewert Posted August 23, 2018 Share Posted August 23, 2018 I built this hair clasp because my wife was feeling a little left out of the product flow (too many bottle openers for the guys). I didn't really know what I was doing, but I did manage to cob together a functional piece. If I had to do it again I'd make the leaves a little smaller and the loops a little bigger. I also need to get a decent torch, since the leaves took a beating having to be reheated so many times to get the loops right. I used 3/32" rod with the leaves welded on. Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 24, 2018 Share Posted August 24, 2018 Well done Hans.. I like all you have done.. I hope the neighbor is a little better now.. Ted, those are great.. I'd wear them.. I might have to make a set myself.. And here is what I made in the shop between yesteday and today to test out the Wrought iron hammer build.. The one of the right is the new one.. of course i have to get the hammer in there.. Link to comment Share on other sites More sharing options...
Ranchmanben Posted August 24, 2018 Share Posted August 24, 2018 I watched the Peter Ross video on building a set of dividers and gave it a whirl. I’m reall happy with my first go but I think it was just beginners luck. Also, the rivet on the other side looks pretty rough. Maybe another dozen tries and I’ll have a pair as good as this one. Link to comment Share on other sites More sharing options...
Zrognak Posted August 24, 2018 Share Posted August 24, 2018 On 8/16/2018 at 2:06 PM, SLAG said: Look on the bright side. You got two blades for the price of one! Sorry I missed this post, humorous Link to comment Share on other sites More sharing options...
Mark Ling Posted August 25, 2018 Author Share Posted August 25, 2018 Here is some recent stuff. 3-d horse head bottle opener (actually a really simple thing to forge), sea horse wall hook (proportions are off, next one I hope will be better), hot chisel, feather wall hook that I actually like, top fuller, and cupping tool. also forged a pair of tongs from a set of blanks I got from Ken's Custom Iron. Also here is some pics of a photo shoot. I like them. Littleblacksmith Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 25, 2018 Share Posted August 25, 2018 Wow Mark, you have come such a long ways.. Wonderful, simply wonderful.. Nice work.. Lovely looking pictures.. Link to comment Share on other sites More sharing options...
Mark Ling Posted August 25, 2018 Author Share Posted August 25, 2018 Thank you! Littleblacksmith Link to comment Share on other sites More sharing options...
Al Stephens Posted August 25, 2018 Share Posted August 25, 2018 Keep up the good work Mark. Al Link to comment Share on other sites More sharing options...
Mark Ling Posted August 25, 2018 Author Share Posted August 25, 2018 Thank you very much! Littleblacksmith Link to comment Share on other sites More sharing options...
Hans Richter Posted August 25, 2018 Share Posted August 25, 2018 Made a start to build a kiln to burn out my lost wax moulds for the (future) bronze and silver castings. Use the 55gal oil drum witch followed me home. Will use him twice, ones as a ‘Bell’-configuration (on a gallows) while burn out the wax (lid attached to the midsection) and also as a ‘top-loader’ (midsection attached to bottom) to burn ceramic raku, biscuit and pottery for Lisa. After preparing the shell with all necessary issues (exhaust, burner connectors, wax collector/drain, gallows, mobile trolley) I will insulate them with 2in of rigidized Superwool. Keep u update with the progress. Cheers, Hans Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 25, 2018 Share Posted August 25, 2018 Hans what will you use to keep the sections in alignment? Looks great so far.. Did you find information on the build online or something you have read up on? Link to comment Share on other sites More sharing options...
Tommie Hockett Posted August 25, 2018 Share Posted August 25, 2018 Howdy howdy fellers and ladies Im back after a long absence. Appreciate all the prayers while I was gone. My wife has been practicing making horse shoe hearts and I actually had a spare moment for a change.... not really I just made the time to get out to the forge and she showed me how to do it. It may not be the purtiest thing but I am stinkin proud of it and my wife for taking out all the hard work for me haha. Thanks for looking yall and if you have any tips theh are very welcome Link to comment Share on other sites More sharing options...
Daswulf Posted August 26, 2018 Share Posted August 26, 2018 Looks good Tommie. Just wait till you figure out how to make the horse heads on the ends. Link to comment Share on other sites More sharing options...
Frosty Posted August 26, 2018 Share Posted August 26, 2018 Looking good Tommie. The only tip I have for you is HOLD ONTO YOUR LADY WIFE!!! Frosty The Lucky. Link to comment Share on other sites More sharing options...
Tommie Hockett Posted August 26, 2018 Share Posted August 26, 2018 Appreciate it yall!!! And that is just what I plan to do frosty Das, I figure that I have made one heart so now I must be an expert smith so onto sword smithing I go... Link to comment Share on other sites More sharing options...
JHCC Posted August 26, 2018 Share Posted August 26, 2018 Check with your wife first. Link to comment Share on other sites More sharing options...
jlpservicesinc Posted August 26, 2018 Share Posted August 26, 2018 Tommie Hockett.. I am with you brother.. Forge swords and smith ON... Can't wait to see it.. SWEEEEETT... Link to comment Share on other sites More sharing options...
Please sign in to comment
