Daswulf Posted April 11, 2018 Share Posted April 11, 2018 Nice lengthwise punching! Link to comment Share on other sites More sharing options...
Ranchmanben Posted April 12, 2018 Share Posted April 12, 2018 Thank you Das. That was first for me. The ugly sides will get covered up by the motises in the other parts. Hopefully I can do a cleaner job on the next ones since they will be visible. Link to comment Share on other sites More sharing options...
JHCC Posted April 12, 2018 Share Posted April 12, 2018 Glad to see you haven't gone off your rocker. Link to comment Share on other sites More sharing options...
Daswulf Posted April 12, 2018 Share Posted April 12, 2018 Ugh.... Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 12, 2018 Share Posted April 12, 2018 When Grandma gets into a barroom brawl I want to be on *her* side! Did you predrill a starter hole to get the deep holes lined up and oriented? Link to comment Share on other sites More sharing options...
Ranchmanben Posted April 12, 2018 Share Posted April 12, 2018 2 hours ago, ThomasPowers said: Did you predrill a starter hole to get the deep holes lined up and oriented? I didn’t but I think I will on the top of the chair back. Link to comment Share on other sites More sharing options...
Frosty Posted April 12, 2018 Share Posted April 12, 2018 This is a pretty ambitious piece and it's looking darned good. How much do you think it's going to weigh? Frosty The Lucky. Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 12, 2018 Share Posted April 12, 2018 looking a bit Charles Rennie Mackintosh-ish to me. Link to comment Share on other sites More sharing options...
ausfire Posted April 12, 2018 Share Posted April 12, 2018 Great work on the most robust of rocking chairs! You would want to keep toes out of the way when Granny gets that thing a-rockin'. Link to comment Share on other sites More sharing options...
jlpservicesinc Posted April 12, 2018 Share Posted April 12, 2018 Ausfire: , toes, kitty tails, doggy tails.. extension cords, Christmas lights, hardwood or soft wood floors.. Makes me wonder if someone has had a lot of rockers stolen or destroyed by family on game nights.. this will cure both.. Ranchmanbeb nice work.. all things said in jest.. i am curous about the rockers, the contact patch for a rocking chair is suppose to be pretty thin on the runners.. wood bolted to the metal? Link to comment Share on other sites More sharing options...
Ranchmanben Posted April 12, 2018 Share Posted April 12, 2018 8 hours ago, Frosty said: This is a pretty ambitious piece and it's looking darned good. How much do you think it's going to weigh? Frosty The Lucky. This is certainly the most ambitious forging project I’ve taken on but I’m entered in a contest so I want to win. I’m hoping it’ll be around 100lbs but it’s probably going to be heavier. 7 hours ago, ThomasPowers said: looking a bit Charles Rennie Mackintosh-ish to me. I’ll have to look that one up. It’s inspired by a chair forged by Tim Cicineros. 3 hours ago, ausfire said: Great work on the most robust of rocking chairs! Thank you Sir 2 hours ago, jlpservicesinc said: Ranchmanbeb nice work.. all things said in jest.. i am curous about the rockers, the contact patch for a rocking chair is suppose to be pretty thin on the runners.. wood bolted to the metal? The contact area of the rockers is one place I’m hung up. Part of me wants to just make them all metal and use it only on carpet. The other part wants to make it more versatile and and usable on multiple surfaces. I was thinking about attaching a strip of harness leather. Link to comment Share on other sites More sharing options...
JHCC Posted April 12, 2018 Share Posted April 12, 2018 12 minutes ago, Ranchmanben said: It’s inspired by a chair forged by Tim Cicineros. I was thinking Sam Maloof. 12 minutes ago, Ranchmanben said: The contact area of the rockers is one place I’m hung up. Part of me wants to just make them all metal and use it only on carpet. The other part wants to make it more versatile and and usable on multiple surfaces. I was thinking about attaching a strip of harness leather. Harness leather will eventually (and inevitably) compress, stiffen, crack, and break. What if you were to make the rockers out of angle iron, with the horizontal leg on the inside? That would distribute the weight over a wider area, and if you take some care over grinding the underside smooth and rounding the bottom edges, you won’t have to worry about it scratching the floor. Link to comment Share on other sites More sharing options...
Ranchmanben Posted April 12, 2018 Share Posted April 12, 2018 I’ll be mighty pleased if mine turns out a quarter as pretty as a Maloof chair. I’m pretty sure any metal, even highly polished would eventually start tearing up a wood floor from dust getting ground into it. I don’t want to use it but I think some sort of hard rubber belting riveted on would be best Link to comment Share on other sites More sharing options...
Daswulf Posted April 12, 2018 Share Posted April 12, 2018 Ben, if you could find some nylon plastic strips for the bottom of the rockers they would flex enough to conform to the curve and be able to be shaped to fit neatly and drilled to counter sink screws into the metal. I think that would make for a nice safer durable liner. Link to comment Share on other sites More sharing options...
HammerMonkey Posted April 12, 2018 Share Posted April 12, 2018 1 hour ago, Ranchmanben said: I’ll be mighty pleased if mine turns out a quarter as pretty as a Maloof chair. Maybe some wood strips on the bottom of the rockers, countersunk and riveted. you could also do wood strips on the armrests as accents to tie in with the rockers. Link to comment Share on other sites More sharing options...
Glenn Posted April 12, 2018 Share Posted April 12, 2018 Put wheels on the rockers, that way Granny can rock and roll. Wear resistant plastic, like they use as power hammer guides, could be glued to the rockers and then be replaced as needed. If anything gets between the rockers and the floor, dust, dirt, debris, etc. will in time abrade the floor due to the motion of the rocker. Maybe glue on some strips of indoor/outdoor carpeting? Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted April 12, 2018 Share Posted April 12, 2018 Grit will embed into the softer material (wood, leather, plastic, etc) and work like a lap. A hard surface won't allow that to happen. When lapping bores the lap has to be softer than the material being lapped to size, otherwise the lap gets lapped instead. To avoid wear on a wood floor I would make the runners wide to spread the weight out, and give the edges a good radius. Wide runners would also allow it to be used outside on the grass or dirt. 2"-3" wide would probably do it. The toughest part may be getting them to be lay flat at all points. Link to comment Share on other sites More sharing options...
Glenn Posted April 12, 2018 Share Posted April 12, 2018 If there are children involved, make the rockers so the chair resists turning over backwards when rocked excessively. Link to comment Share on other sites More sharing options...
SLAG Posted April 12, 2018 Share Posted April 12, 2018 2 hours ago, Daswulf said: if you could find some nylon plastic strips for the bottom of the rockers they would flex enough to conform to the curve and be able to be shaped to fit ... High density polyethylene strips may work better and last longer than nylon. But where do we get that material? A search may be worth the time involved. Just ruminating. SLAG. Link to comment Share on other sites More sharing options...
Daswulf Posted April 12, 2018 Share Posted April 12, 2018 SLAG, many different products come up with a quick google search of "nylon plastic strips" I'm sure a through search would yield a good product for the job. I do like the wood idea mentioned by monkey as well. I think in the end tho, I'd make it what it is and let the user purchaser deal with how they intend to use it with maybe just suggesting using it with a rug or carpet under it if they have hardwood floors. To an extent you just can't worry about fingers and tails getting under it in use otherwise we are getting into the rubber room mentality again and just shouldn't make such dangerous things. Just don't make the rocker sharp like a blade Link to comment Share on other sites More sharing options...
Ranchmanben Posted April 12, 2018 Share Posted April 12, 2018 I’m liking the idea the idea of wider rockers, with or without some sort of padding. Part of me think that if someone puts it on a wood floor with out a rug then they deserve what they get. The danger of toes, tails or other things getting mashed isn’t my concern. Those are the dangers of any rocking chair. We’ll see how it goes and how much motivation to do extra work I’ve got when I get to the rockers. Link to comment Share on other sites More sharing options...
John in Oly, WA Posted April 12, 2018 Share Posted April 12, 2018 Don't know how far along you are, and it would certainly shift it to a non-traditional look, but you could make the bottom a "glider" style of rocker and solve all those problems - even the toes and cat tails. Of course, then it'd probably weigh 200 lbs. Link to comment Share on other sites More sharing options...
Daswulf Posted April 12, 2018 Share Posted April 12, 2018 23 hours ago, Ranchmanben said: I’m liking the idea the idea of wider rockers, Oh great! Now you have me thinking about the two metal wagon wheels I have out side. Cut one in half, open it up a little and done. Link to comment Share on other sites More sharing options...
Frosty Posted April 12, 2018 Share Posted April 12, 2018 You can buy UHMW strips and runner bolts. Dog sleds in Alaska haven't run on wood or whale baleen contact surfaces since the early mid '70s. The plastic, used to be called "P Tex" but there are other makers now. Anyway, it doesn't pick up sand or gravel, when it is pressed into the plastic, the plastic gives then rebounds popping it back out. Dog sleds with gravel embedded in the runners would be too hard to pull, even on snow let alone ice. Anyway, the product for exactly what you need is available. Maybe check dog sled supplies, I have an acquaintance who's a racer and sells supplies, he'll know. I'll get back with product name and company. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Ranchmanben Posted April 13, 2018 Share Posted April 13, 2018 5 hours ago, Daswulf said: Oh great! Now you have me thinking about the two metal wagon wheels I have out side. Cut one in half, open it up a little and done. You and I are on the same page with the wagon rims! Thanks Frosty. Sounds like an ideal material. Suppose it comes in a dark grey? Link to comment Share on other sites More sharing options...
Please sign in to comment
