Krack Posted August 15, 2020 Share Posted August 15, 2020 I have wool coated with rigidizer. I wanted to coat that with layers of satanite, but I am finding that this is very not ideal because the rigidizer has a somewhat dusty surface and doesn't allow the satanite to stick well. If it does stick, the satanite sometimes pulls and detaches the rigidizer from the wool. Sometimes applying pressure cracks the rigidizer layers. So... Is this similar to other people's experience when putting satanite onto rigidizer??? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 15, 2020 Share Posted August 15, 2020 I applied a 1/2 inch layer of Satanite over rigidizer with no problems. What did you use as rigidizer, how was it mixed? I've never seen a rigidizer that was mixed properly have a dusty surface. Quote Link to comment Share on other sites More sharing options...
Krack Posted August 20, 2020 Author Share Posted August 20, 2020 it came with the furnace as a kit. I think it looks fine, felt fine, mixed, applied, and set well. it's definitely slightly dusty. Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 20, 2020 Share Posted August 20, 2020 Welcome aboard Krack, glad to have you. If you put your general location in the header you'll discover how many members live within visiting distance. A couple hours with an experienced smith is worth many times as much as trying to figure it out yourself. What you got with the kit isn't a rigidizer, it's some sort of refractory flame face. A rigidizer literally soaks into the ceramic blanket and when heat cured stiffens it while encapsulating the fibers making them much less likely to break off and end up in your lungs. Try doing a gradual heat cure of the stuff they sent you. After drying thoroughly light the burner and let it heat for a couple minutes, let it cool then heat it up again to low or barely visible red heat and let it cool. A 3rd time to working temperature and it should be ready to work in. Then after it's cool, wipe the inside with a wet sponge to remove any dust and dirt, then apply the Satanite WHILE IT'S STILL WET from wiping it down. The wet surface is "Buttered" and will ensure the Satanite will bond properly to the cured refractory liner. If it still fails you can buy a high end water setting bubble alumina refractory in reasonable quantity from the Iforge store, the button is in the top line of every page. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
