Anachronist58 Posted August 11, 2020 Share Posted August 11, 2020 Client up in Kern County wants some rusty samples. He will receive some rebar, excavated after 47 years, and some rusty dia. 5/16" wire rope, patina age unknown. I decided to try my hand at rapid patination, so I immersed a very clean dia. 1-1/2" 52100 bearing ball in 40% vinegar for 8 days. Over those days, the solution went from clear, to claret, to blue, to blue-green, to black. The reaction was still vigorous when I removed the ball: I then wiped down the ball - pretty dark grey, and encased it in vinegar soaked virgin gabbro semi clay. It sat for four days in 90°F sun (not nights, this aint Floridia). Here is what I got: Next one with be straight into the vinegar clay, to maybe remove a step. Robert Taylor Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 11, 2020 Share Posted August 11, 2020 Looks a lot like the mill balls I buy at the scrapyard. Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted August 11, 2020 Author Share Posted August 11, 2020 Was a super shiny bearing ball from the Grand Coulee Dam. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 11, 2020 Share Posted August 11, 2020 And so best forged into a blade, rather than a rusty lump that could be impersonated by a mill ball? Or was that just for experimentation? Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted August 11, 2020 Author Share Posted August 11, 2020 Experimentation, Thomas, as succinctly stated in my first post. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 11, 2020 Share Posted August 11, 2020 Trying to do something does not necessarily mean experimentation to me. Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted August 11, 2020 Author Share Posted August 11, 2020 I have not the intelligence sufficient to satisfy your pedantry. Experimentation was succinctly implicit in the OP. I am sure you will have the last word. Respectfully, Robert Taylor Quote Link to comment Share on other sites More sharing options...
Scott NC Posted August 11, 2020 Share Posted August 11, 2020 I dont mean to pry, but what role does the temperature play? It is not well known but I am a big fan of corrosion/rust. The faster it happens the better. Except on my truck and mower deck. I wonder how sodium hydroxide would work. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 11, 2020 Share Posted August 11, 2020 Actually I was interested to know if you planned to duplicate the finish on a 52100 knife blade and hence used the bearing as a test vehicle. Besides bearings and knives I don't know much that alloy is used for. I was asked to duplicate an early 19th blade once and to make it appear as if it had the same patina on it as the museum piece. I was willing to do so; but on the inside of the handle scale I inlet the year I made it and embedded lead solder---if it gets xrayed it will show it's not "original". (I've had a number of discussion with various reenactors trying to point out that if they got a blade or other piece of kit for their portrayal it should NOT look like it was centuries old. It should look like you had bought it new within the last couple of years. (At the medieval technology conference, Penn State a couple of decades ago; there was a very interesting presentation by Dominic Tweddle on the Goldsmiths house in York that they had just finished restoring about the same issue---everything was to look new and recent except for one chest that was listed in an original inventory as having been inherited and so it was made to look a generation older.) Higher temps == faster chemical reactions which are sometimes good and sometimes bad to get the patina you want. Old crock pots are often handy to hold solutions at warmer temps but PLEASE mark them NOT FOR FOOD USE! (Slower reactions are sometimes denser and more adherent than faster ones which are "featherier" ) Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted August 11, 2020 Author Share Posted August 11, 2020 I have only begun to "experiment". I am an uncredentialled amateur, but I do know that in general, raising the temperature often accelerates the reaction. I do not know about sodium hydroxide, but Keep in mind that mixing common household chemicals can result in unwanted violent reactions. Robert Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 11, 2020 Share Posted August 11, 2020 Or toxic fumes, (ammonia and bleach for instance.) There is a smith in Northern New Mexico who makes up a lot of stock and then has it naturally patinating out back of the shop for years to get a good adherent rust patina. (Last time I visited him he had just finished a US$90K commission.) Quote Link to comment Share on other sites More sharing options...
Scott NC Posted August 11, 2020 Share Posted August 11, 2020 I've worked with lye before but never soaked anything in it. Yes, Thomas, no chloramine gas for me please. I always thought it was chlorine gas but google says chloramine. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 11, 2020 Share Posted August 11, 2020 9 minutes ago, Nodebt said: I've worked with lye before but never soaked anything in it. I'm not going to lye: I've never even made a base-line experiment with it. Quote Link to comment Share on other sites More sharing options...
Scott NC Posted August 11, 2020 Share Posted August 11, 2020 This atmosphere is getting too caustic for me! Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted August 11, 2020 Author Share Posted August 11, 2020 Perhaps a bit of buffering will help, or will it only serve to compound the mess? Quote Link to comment Share on other sites More sharing options...
Stash Posted August 11, 2020 Share Posted August 11, 2020 One of the demonstrators at ABANA in Richmond talked about his "drainage ditch patination process". I guess it takes a little longer. New England School of Metalwork suggested a spray composed of (if I remember correctly) vinegar, salt and hydrogen peroxide. Just spray it frequently on your piece for a few days and a nice crusty patina builds up. Steve Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 11, 2020 Share Posted August 11, 2020 I've used lye solutions to clean crud off of cast iron cookware. Very effective no danger of warping or cracking like the burn off method. You do need to take proper precautions to safely use it. Quote Link to comment Share on other sites More sharing options...
