Jaegers Forge and Foundry Posted July 22, 2020 Share Posted July 22, 2020 I decided to take my metal detector around my property and I'm glad I did. first I found this huge thing of rebar that was around ten feet tall (It's bent) here's a picture of me next to it (I'm 5'10) Next I found all these Can anyone tell me what these are? Quote Link to comment Share on other sites More sharing options...
1forgeur Posted July 22, 2020 Share Posted July 22, 2020 Wedge to split wood with a sledge Quote Link to comment Share on other sites More sharing options...
Jaegers Forge and Foundry Posted July 22, 2020 Author Share Posted July 22, 2020 Thats what I thought. Any idea if its good steel? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 22, 2020 Share Posted July 22, 2020 There are generally excellent steel to make wedges for splitting wood from. Whether a steel alloy is "good" or not depends on what you want to make from it and the properties those items need. Just like gasoline is a terrible fuel for your car---if you have a diesel engine in your car. Another example: is 1005 steel "good"? I want to do a repousse belt buckle; would 1005 steel be good? YES, the extremely low carbon would make it easy to work. I want to make a fillet knife; would 1005 steel be good? NO! Can't harden it, won't keep an edge and will take a set easily in use. Spark test it; they are often medium carbon steel; though I have run into some mild ones. High carbon wedges are not a good thing due to their greater danger of cracking or spalling. If they test as mid C then hammer heads would be "good" and knife blades not so "good". Quote Link to comment Share on other sites More sharing options...
