Smeden gegen Posted July 18, 2020 Share Posted July 18, 2020 Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 18, 2020 Share Posted July 18, 2020 What's it made from? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted July 19, 2020 Share Posted July 19, 2020 It looks like a 5 blade fan and one is missing to me. Quote Link to comment Share on other sites More sharing options...
Smeden gegen Posted July 19, 2020 Author Share Posted July 19, 2020 This old thing is made from mild steel plate (fan blade) 4 blade construction Quote Link to comment Share on other sites More sharing options...
Latticino Posted July 19, 2020 Share Posted July 19, 2020 I would carefully clean the surface of the broken blade, then torch braise a sheet metal "bandage" over the broken part. It is hard to tell from your photo, but you might want to extend the "bandage" right up to the center cylindrical core. Airflow at that point on the blade is not overly critical, so you should be able to get by with a modicum of sanding to lightly flush it out. If you can add a bit of weight to the opposite side blade to balance the impeller that would be a good job as well. Quote Link to comment Share on other sites More sharing options...
Smeden gegen Posted July 19, 2020 Author Share Posted July 19, 2020 Got more pics to help Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted July 19, 2020 Share Posted July 19, 2020 I would do the repair as Latticino said. Tig welding could be used also, but it will take someone who is good at that. The main thing is to get it super clean. Quote Link to comment Share on other sites More sharing options...
