Rojo Pedro Posted June 22, 2020 Share Posted June 22, 2020 Picked up a few breaker bits at the scrap yard and decided I needed a bick to go between punch and horn when making bottle openers..... this one is a Brunner - Lay and although tough, it moved considerably easier than a Vulcan bit I tried earlier (ended up cracked and burned in coal forge) it works fine but I found that it doesnt work as well as my Holland cone for that purpose possibly the mass of the cone but likely user errors Fun to make. Thanks for looking Quote Link to comment Share on other sites More sharing options...
Rojo Pedro Posted March 2, 2021 Author Share Posted March 2, 2021 Just a follow up. Even though it bounces around a bit, I find that I use this bick fairly often and it has been a good addition to my tool set -fyi Quote Link to comment Share on other sites More sharing options...
Daswulf Posted March 2, 2021 Share Posted March 2, 2021 Nice RP. They have their uses and are handy to have. Try some painters masking tape around the hardy stem. It will snug it up in the hole and bounce around less. It doesnt last long with installing and removing the tool but it will work when you need it more steady. Just try with one wrap first then see if it is more snug. Repeat the wrap untill it fits more snug and wiggles less. I prefer masking tape over duct tape. It's easier to remove when it needs redone or just needs removed, and it is less likely to get the tool more stuck in the hardy hole. Another better tape than duct tape for this is gaffers tape. And also there is aluminum foil tape which might last longer than the other two if you do a good job of getting it wrapped smooth and tight around the hardy stem. (No folds or creases). Quote Link to comment Share on other sites More sharing options...
JHCC Posted March 2, 2021 Share Posted March 2, 2021 Or run a weld bead down the middle of two sides and file them down as needed for a perfect fit. Quote Link to comment Share on other sites More sharing options...
Rojo Pedro Posted March 2, 2021 Author Share Posted March 2, 2021 Thanks Gents Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 2, 2021 Share Posted March 2, 2021 The problem being that if you fit it to the hardy hole hot; it shrinks when it cools. Or the hardy hole may be worn if you use dimensional steel for the stem. Or the hole wasn't exact to begin with Or all three! Quote Link to comment Share on other sites More sharing options...
Rojo Pedro Posted March 2, 2021 Author Share Posted March 2, 2021 Yup. It did shrink a bit and the hole is not quite square so its a bit looser when installed in one direction or another but it cant get stuck in any direction. i am going to try Mr. Wolfs tape suggestion Quote Link to comment Share on other sites More sharing options...
