Propane hose heat tolerance
JCL BlackSmith
Welcome aboard JCL, glad to have you. If you put your general location in the header members near you can provide location specific: answers, information and invites.
If you can hold it, it's a long way from too hot. If you want to isolate it, I recommend placing a fitting to connect the hose down below the forge and running copper tubing to the burner itself.
  • 9 months later...
Someone said you should sleeve the hose. If the hose is getting hot because of proximity to the forge this may be a good idea. If it is getting hot because the burner is transferring heat to it insulating with sleeving is a waste of money and a very bad idea. It will make your problem worse because the hose can’t transfer heat to the air around it.
