Glenn Posted May 31, 2020 Share Posted May 31, 2020 Once you have a working air supply you CAN start blacksmithing. You may want to look into a box bellows. They have been used for years and are a simple build. Quote Link to comment Share on other sites More sharing options...
natkova Posted May 31, 2020 Author Share Posted May 31, 2020 1 hour ago, Glenn said: They are interesting Glenn i might give it a try. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 1, 2020 Share Posted June 1, 2020 Note that they blow on both the push and the pull stroke only at turnover does it stop pushing air. Quote Link to comment Share on other sites More sharing options...
natkova Posted June 1, 2020 Author Share Posted June 1, 2020 37 minutes ago, ThomasPowers said: That is downside , you need to be constantly at forge. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 1, 2020 Share Posted June 1, 2020 That's what apprentices were for! Journeymen for Strikers. Having only a single smith in the smithy is a modern perversion! Quote Link to comment Share on other sites More sharing options...
natkova Posted June 2, 2020 Author Share Posted June 2, 2020 Thomas you mean thralls Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 2, 2020 Share Posted June 2, 2020 It's what makes historical blacksmithing so enthralling! Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 2, 2020 Share Posted June 2, 2020 "Apprentice" is how Blacksmiths spell "thrall". Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 2, 2020 Share Posted June 2, 2020 "Apprentice" is how Blacksmiths' thralls spell "thrall". Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 2, 2020 Share Posted June 2, 2020 I was probably thinking about "help wanted" adds. Who cares how thralls spell so long as they don't forget what you send them to do or get. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted June 8, 2020 Author Share Posted June 8, 2020 On 5/31/2020 at 7:42 PM, Frosty said: You don't need to have the bellows even with the tue, it only needs just enough space it doesn't hit the rafters. Move it higher it can be over a work bench you aren't using while forging. put a loop or knot in the cord used to pump it so you can lift the bottom leaf so you don't bang your head. Make it square and put it in a corner if that works best. The bellows doesn't need to be at the forge, that's what air ducting is for. Frosty The Lucky. It looks like those bellows are just what i need, i put less weight on top chamber so it squeze steady air and it is better, now well i get it to yellow color today listening to advice put less amount of fuel like fingernail size, it get heated slowly but it get heated , even tuyere today were yellow Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 8, 2020 Share Posted June 8, 2020 Excellent, that makes me feel good. Keep making little adjustments and experimenting and you'll have that forge purring like a kitten for you. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted June 8, 2020 Author Share Posted June 8, 2020 Iam not yet ready for forge welding so i don't need it bright white color, but i gues it could be done but in lot's of longer time. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 9, 2020 Share Posted June 9, 2020 Maybe not but you have better control of your fire and that's what counts. With control you can make it as small or large or as hot as you need. If you're concerned with being able to make forge / fire welds, that's a different issue and we'll help you build the TYPE fire that works well and help you learn how to weld. Welding isn't difficult there are just steps to follow. That's it, just follow the steps. Forge welding is for another thread in a different section where we'll be more than happy to help as best we can. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted June 9, 2020 Author Share Posted June 9, 2020 10 hours ago, Frosty said: Maybe not but you have better control of your fire and that's what counts. With control you can make it as small or large or as hot as you need. If you're concerned with being able to make forge / fire welds, that's a different issue and we'll help you build the TYPE fire that works well and help you learn how to weld. Welding isn't difficult there are just steps to follow. That's it, just follow the steps. Forge welding is for another thread in a different section where we'll be more than happy to help as best we can. Frosty The Lucky. Hwre is my anvil same size as bellows , dont need bigger for now. I think it is better than sledgehammer. Quote Link to comment Share on other sites More sharing options...
