Troyellisonjr Posted May 20, 2020 Posted May 20, 2020 Looking to ID this anvil. Any help would be appreciated :) Quote
Irondragon Forge ClayWorks Posted May 20, 2020 Posted May 20, 2020 At 280 pounds a good sized MH. How is the face? I can see some chips & a little sway but not bad. BTW Welcome to IFI, I always suggest reading this to get the best out of the forum. READ THIS FIRST It's full of tips like editing your profile to show your location and many others. Quote
ThomasPowers Posted May 21, 2020 Posted May 21, 2020 2 x 112 = 224 + 2 x 28 = 56 + 11 ==> 291 stamped weight. (It will run a bit under the stamped weight though.) Quote
Irondragon Forge ClayWorks Posted May 22, 2020 Posted May 22, 2020 I used an anvil weight calculator to get the weight and must have forgot number 11 for the last one. I'll take the blame on that one because being distracted with my wife having had cataract surgery that day. I'll go sit in the corner now. Quote
ThomasPowers Posted May 22, 2020 Posted May 22, 2020 Thought maybe you were trying to confuse a Razorback there...With the often seen stamped vs weighed differential you were probably real close anyway. Quote
