Weak flame from devil forge burner... why?!?!
Hoax365
Hello, I am new to the melting community and bought a devil forge recently.  It's the small one.  Been collecting aluminum cans and cutting them in half to get into the melting and will work my way up.  I am having issues and need help.
When I fire up the furnace, I have a very weak flame.  The propane tank is full, and I have the regulator that the furnace came with set at .1.  My flame is so wimpy and lame that when I adjust the choke the flame dies.
Can anyone give me help?  I emailed devil forge.  I think it's an altitude issue because I live in Albuquerque... about a mile above sea level.  Other ideas??
NO, it's not an altitude issue.
If the forge has an adjustable regulator (which has been standard on them so far), turn it up.
If your problem persists, send us some photos of the forge running. Also, take the burner out of the forge, run it in the open air, and send a photo of that, too.
Welcome!  Too bad we are lockdown or I could suggest taking it to a New Mexico Artist Blacksmith Association meeting, (where I could look it over.) Did you buy it directly from Devil Forge?  If so you are going the right direction by asking them to support their product.
BTW is that .1 Bar or .1 PSI on the gauge?  If it's .1 PSI I would assume that it's way too low. I noticed their website mentions regulators in both PSI and Bar and as .1 bar is about 1.45 psi it would definitely make a difference!
Anyway; if you have any interest in blacksmithing and not just foundry work; stop by sometime you are in the neighborhood---after the lockdown is over of course; I can take you to my favorite "prowl the piles" scrapyard down here. I'm near Socorro and use a naturally  aspirated  forge quite a bit.
I can't think where I've seen it, but I have a feeling that Devil Forge may use a MegaPascal-marked gauge, though I would imagine this may vary by destination. The cylinder fittings vary by country and, IME, regulators usually come with gauges marked in the customary units for the country/region they fit.
.1 MPa is 1 bar or 15 PSI.
