Help with Anvil ID
WHAT COUNTRY IS IT IN?  If you had a used car would it be more likely to be a Lada or a Ford---makes a huge difference if it's in Russia or the USA right?
To know if it's a good anvil you don't need to know the brand. You need to know the results of the ball bearing test and the ring test---done by someone who can evaluate those results.  Just from the pictures I would be wary that it's a cheap cast iron anvil. It could be a nice cast STEEL anvil though and the tests will tell you!
Welcome aboard... Have you read this yet?  READ THIS FIRST   It will help you get the best out of the forum with tips like editing your profile to show your location, and many others to help stay off the moderators radar.
More pictures are needed from different angles and one of the bottom of the base to even begin to ID it.
Updated, thanks! I will try to get some more pictures.
USA> Thanks, I will try and get some more info.
