Justwood&iron Posted March 2, 2020 Share Posted March 2, 2020 When welding an anvil together with 1" thick pieces, what degree and depth of bevel is the best? What amperage is required? Can you use E7018 or E7014 electrodes? Quote Link to comment Share on other sites More sharing options...
John McPherson Posted March 2, 2020 Share Posted March 2, 2020 As with all welding, 100% penetration is best. Anything less will lead to some sort of compromise in rigidity or life span before failure. What do you have to bevel with? Files, small grinder, huge grinder, oxyfuel torch and cutting head, carbon arc gouger? What kind of weedburner do you have to preheat the plates to 300F before you start tacking up? How big are your welding rods? Is your supply unlimited? How beefy is your power supply? Do you have a shop crane and chain hoist to manipulate the work on the steel welding table so that you can do all of the welds in the flat or horizontal position? How about a just a sturdy steel bench and a crowbar, unless you just like squatting in the dirt for hours? How good is good enough for a home made project? I assure you that plenty of third world smiths are making a living with far less than a welded up anvil, even a student version. Quote Link to comment Share on other sites More sharing options...
caotropheus Posted March 2, 2020 Share Posted March 2, 2020 I second Mr. McPherson answer. Always 100 % full penetration. I suppose you saw my Youtube videos on how I built my anvils, I welded with 7018 rods and I used a 3 phase arc welding machine that gives me 250 Amps, power supply 380 V 3 X 16 Amp duty cycle 100% at 180 Amp. I used 4 mm rods rated for 140 -190 amps. With my machine I could have used 5 mm rods rated for 240 Amps but I did not want to burn neither the welding machine nor the electricity wiring at home. If you can use bigger diameter rods even better, you will finish your work faster. To use machinery that require more Amperage I am changing now my power supply from 3X 220V 25 Amp to 3X 220 V 40 Amp. As I said before, in my area anvils are extremely expensive and it is cheaper for me to build an anvil if I can source the right materials from the local junkyard. Rods, discs and electricity at my place are also fairly cheap. I takes a long time, but I am stubborn enough to weld an anvil together and when you finish it it gives you a huge satisfaction and sense of accomplishment. So go forward with your project but if you do not show us pictures/videos, it did never happened... Quote Link to comment Share on other sites More sharing options...
bluerooster Posted March 5, 2020 Share Posted March 5, 2020 I cut a wide deep bevel on mine, and used many many 7014 rods, at about 120 amps. It performed very well with good penetration. But took a while, as at that amperage my machine is only about 60% duty cycle. Welds burned right in, nice and flat, with very little grinding. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted March 6, 2020 Share Posted March 6, 2020 A lot would depend on the design and construction of the anvil. Plated aligned vertically I would say, bevel and weld. Horizontally-100% penetration to eliminate any gaps that could spring. Again, depends on the details. Quote Link to comment Share on other sites More sharing options...
tanglediver Posted March 6, 2020 Share Posted March 6, 2020 The included angle we ran on full pen., 1" plate, butt joints was 60*, so 30* each edge which we precut with a track burner. That was just for test plates. The configuration of the pieces and the type of joint will dictate the angle that works well. A very wide angle will take a lot more weld metal than a very narrow one, and there are lots of different joint configurations, different groove shapes etc. I ran 1/8" E7018 at 118 ~ 125 amps with preheat of 150* on mild steel when I tested. We shot for an interpass temperature of 250*, so that meant allowing enough time to cool to 250* before starting each pass. Making a big chunk of homogeneous steel is not that hard. Making one that serves as a good anvil may be a bit harder! Have fun. I was just remembering a hand made anvil that sat in the lab at school. It looked to be between 100 and 200 pounds. I never did learn the story behind that piece, who made it, how well it worked. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 6, 2020 Share Posted March 6, 2020 Getting a big chunk of homogeneous steel is not hard either.... Quote Link to comment Share on other sites More sharing options...
DuEulear Posted March 6, 2020 Share Posted March 6, 2020 I second the notion that large chunks of homgeneous steel is not difficult in the modern day i needed a show anvil for a viking themed fair there where no rules but i wanted to be a touch more authentic i grabbed a scrap end of 8” square bar of prehardened 4140 ended up with a 115 lb block without trying very hard spent 3 hrs putting a 1” hardy hole in and love the result ps if you are anywhere near me i can keep an eye open for you Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 6, 2020 Share Posted March 6, 2020 115# Viking anvil seems a bit inauthentic; most of the "larger" viking era ones I have seen were rocks. My Y1K block anvil is about 25# and a bit hefty at that! (My set up is based on the Heylestad Church door carvings.) On the other hand; out here site requirements often forbid all but propane forges due to fire risks; nothing more medieval than having the right garb, right tools, right anvil and having to use a propane forge! Quote Link to comment Share on other sites More sharing options...
tanglediver Posted March 7, 2020 Share Posted March 7, 2020 Yes, an existing block trumps hours of blood, sweat and tears. But the OP asked, so I gave it the old college try. Quote Link to comment Share on other sites More sharing options...
Benona blacksmith Posted March 7, 2020 Share Posted March 7, 2020 I am making a 20 lb viking anvil to be given away to a lucky subscriber on my YouTube channel. It is mild steel and will have a hardened steel plate fire welded on. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted March 9, 2020 Share Posted March 9, 2020 For an anvil as pointed out full penetration welds are best but not needed. You could do partial pen welds and have it last 300 years.. It just really depends on your designs and how much you understand weld failure areas. What can be a problem is the HAZ zone if the metal is thinner that the faceplate. I have a stall jack that would crack at the haz zone all the time as it was a narrow section. I just built up the area with every crack and they stopped.. I would have designed it differently but it's still going strong 32 years later. Quote Link to comment Share on other sites More sharing options...
