JaDub Posted March 20, 2021 Posted March 20, 2021 I have some very old belts and need to re-splice them. This is a wonderful thread. JHCC, where did you purchase the Scotch Strapping tape? Quote
SLAG Posted March 20, 2021 Posted March 20, 2021 SLAG, here, Shoe makers and shoe repairers glue leather to leather by using Barge cement. It woks a treat I speak from experience. I replace heals on my , (& my friends, and family's) shoes when the originals wear out. Been doing it for years. Shoe repair sellers carry it as well as all manner of other shoe products. SLAG. Quote
Irondragon Forge ClayWorks Posted March 20, 2021 Posted March 20, 2021 Seeing as the last shoe repair shop anywhere near us closed decades ago. I googled Barge Cement and the first line was Amazon and about 50 other places selling it online. Quote
JHCC Posted March 20, 2021 Author Posted March 20, 2021 Barge Cement and Weldwood Contact Cement both use a polychloroprene (Neoprene) base. Quote
JHCC Posted March 20, 2021 Author Posted March 20, 2021 Got some Weldwood and applied with a plastic spatula: Tape on one side: And on the other: Let cure overnight, and we shall see what we shall see. Quote
Frosty Posted March 21, 2021 Posted March 21, 2021 Reading the Weldwood can reminded me of the story a while back about the gal using spray glue when she ran out of hair spray. The thing that brought it to mind was the maker, Dap and a catchy jingle form my youth. Weldwood a little Dap will do you! Weldwood you'll ha a ave one piece hair! Dad used Brylcreem though not enough to slick his hair down like in the commercials. Shannon and I would sing the jingle when he put it on. Frosty The Lucky. Quote
JHCC Posted March 21, 2021 Author Posted March 21, 2021 My dad was balding already when I was little. I expected to be as well by now (both grandfathers having been quite bald), but so far it's still all there (if greyer than before). 12 hours ago, JaDub said: I have some very old belts and need to re-splice them. This is a wonderful thread. JHCC, where did you purchase the Scotch Strapping tape? Sorry to miss your comment earlier, JaDub, and welcome to IFI! I got the tape at Office Depot. Quote
Frosty Posted March 21, 2021 Posted March 21, 2021 I believe we inherit our hairline from our Mother's side. What I have inheriting from Dad's side is no gray hair, it's fading to white eventually. No distinguished gray at the temples for us, oh no Dad and my uncles enjoyed pink hair till it faded to white. My hair is more brown with red highlights so I'm going to pinkish tan hair with a pink beard. Fastenal or Grainger would be a good places to look for grinding belt tape or cements in these parts. Frosty The Lucky. Quote
JHCC Posted March 21, 2021 Author Posted March 21, 2021 Well, this is my mother’s father when he was substantially younger than I am now: Quote
Frosty Posted March 21, 2021 Posted March 21, 2021 Hmmm, I'll have to see if my little sister has any pics of Dad and his Brothers this is one of the few I have on the comp. Darned if he isn't silver on his temples! It might be stress running his own spinning shop. I'm not sure of the part other than it must be a jet or rocket engine alloy to need that much heat. Holding torch was one of my jobs. Frosty The Lucky. Quote
JHCC Posted March 22, 2021 Author Posted March 22, 2021 Well, I put the finished belts to work today. It was not an unqualified success. The belts in question are 36 grit cubitron (ceramic) and are very thick and stiff and have pretty much zero stretch. While my grinder is nominally a 2 x 90, an actual 90” belt just barely fits on, and then only with a lot of tension. This puts a lot of strain on the joint — more than it can withstand. In short, all the belts I glued up yesterday (two new ones and one old one) ended up self-destructing. Interestingly, the joints stretched a LOT before they finally let go, which tells me that the fiberglass in the tape really gotta have a ton of tensile strength. Here’s one of the belts with about 1-1/2” of stretch, still functioning (if a bit bumpy): I decided to make a couple of belts at 2 x 92, to see if that’s any better. Here’s a 4 x 116 (I think?) cut down to 92” long; I’ll split it when the glue is cured. I’m wondering how much effect the polyurethane will have on this. Of course, finding out will require finding the polyurethane first.... Quote
JHCC Posted March 23, 2021 Author Posted March 23, 2021 Found the polyurethane and sprayed on a coat. Interesting to note that there appears to be a bit of bleeding in at the edges. More to come later; stay tuned! On 3/22/2021 at 1:07 AM, JHCC said: In short, all the belts I glued up yesterday (two new ones and one old one) ended up self-destructing. Forgot to mention: I actually did get some work done with these before their rapid unplanned disassembly. Quote
JHCC Posted March 29, 2021 Author Posted March 29, 2021 Update: split apart the double belt and put it to work over the weekend. Mixed results: The good: no creep. The stretching issues of the previous batch were not in evidence at all. The bad: not as durable as I'd like. After several hours of grinding, the first belt let go, and the fiberglass strands appear to have worn completely through. The second belt is still going strong. A thought that occurs to me is to take some of the Hurricane tape, rub some dust or something on the sticky side to keep the adhesive occupied, and then attach them to the belts upside-down with contact cement both on the belt and on the top side of the tape (without adhesive). One big difference between this tape and the 3M is that the latter has fibers embedded in a plastic matrix, while the former is basically a woven cloth that might be a bit more durable. Quote
JHCC Posted April 3, 2021 Author Posted April 3, 2021 And here we are, giving that a try. Results to be reported later. Quote
JHCC Posted April 4, 2021 Author Posted April 4, 2021 Update: the contact cement didn’t hold, pulling apart from back of the belt. I think I might try this with the polyurethane glue and see how that works. Quote
Irondragon Forge ClayWorks Posted April 5, 2021 Posted April 5, 2021 Have you tried just using the tape without the rubber cement? On my 1X30 that's all I used after making sure the belt backing was clean & dry. Then I used a wallpaper seam roller to set the tape. Of course a 1X30 has a lot less tension on the belt so it may be why it worked for me. Quote
JHCC Posted April 5, 2021 Author Posted April 5, 2021 I might try that with the Hurricane Tape by itself. The bond between the 3M fiberglass tape and the contact cement held together well, but the tape itself wore through too quickly. Quote
Frosty Posted April 5, 2021 Posted April 5, 2021 Do you have a glass or teflon friction pad(?) on the platen? I get noticeably better back side belt wear when I apply a little paraffin wax to the back of the belt. I've been kicking the idea around of getting a friction maybe plate is the term if I start using mine enough. One of the benefits I hear about is them being exactly 2" wide and make for cleaner lines and such. Anyway, something slicker backing them might make your splices last longer. Frosty The Lucky. Quote
Glenn Posted April 5, 2021 Posted April 5, 2021 What type of tape and or glue do the manufactures use? You may want to find a source for that product. Quote
JHCC Posted April 5, 2021 Author Posted April 5, 2021 The only industrial splicing materials I’ve located thus far aren’t available in smaller quantities, have to be stored at below-freezing temperatures, and/or require a heated press. My goal is to find some kind of splicing method that lasts long enough for the grit to wear out. The holding power of the polyurethane adhesive (Gorilla Glue) is great, but neither the denim nor the bias tape is used previously had much staying power. Interesting idea about the friction pad. Quote
JHCC Posted April 5, 2021 Author Posted April 5, 2021 Hmm. It seems one can get flat-woven Kevlar tape: which is expensive, but there’s also woven fiberglass tape available for somewhat less. Quote
JHCC Posted April 12, 2021 Author Posted April 12, 2021 Update: Flipping the Hurricane Tape over did not work, either with contact cement or with Gorilla Glue. The tape is basically too slippery to hold the adhesive. The GG version didn't even last thirty seconds. I've decided that further attempts will be with the GG only. I've had a lot of problems with the contact cement melting from the heat, whereas the polyurethane has never given me any issues at all. It's just a matter of finding the right splice tape material. I think I may have found someone selling small quantities of the industrial splicing tape. I might get some of that and see how it works with the GG. Quote
jlpservicesinc Posted April 12, 2021 Posted April 12, 2021 I have been patiently waiting for your results.. From what I understand they use 2 processes heat activated tape and uv glue. Adhesive Tapes Cloth Tapes NAVIGATION Heat Activated Tape What is Heat Activated Tape? What are the Advantages of Heat Activated Tape? Heat Activated Foam and It’s Possibilities What is Heat Activated Tape? Heat activated tape is usually tack-free until it is activated by a heat source, and is not considered to be a pressure sensitive tape. The industrial bonding and welding of hot-melt adhesives in film form, thermoplastic adhesive films have established a strong position in the last 30 years. Thermoplastics may be reshaped by heating and are typically used to produce or bond parts together by various polymer processing techniques. Thermoplastic adhesive films permit continuous or batch bonding even on large surface areas with a high degree of automation and high production speeds. Materials, from textiles or non-woven to aluminum foil, from PVC to PU foam, can be bonded in calendars, presses or other installations by means of heat, pressure and time. Composites and Textile Industries are among the most appropriate targets for adhesives films since they do not require conditioning lines in the processing plants. It is sometimes used in packaging, for example, a tear strip tape for cigarette packs. This is particularly useful in the semiconductor industry. Heat-activated (hot melt) adhesive systems require a defined period of time at elevated temperatures (normally 180˚F or higher) to achieve final bonding strength. Temperature, pressure and dwell time are used to effect a final cure and bond. Hot Melt Tapes have very strong holding power and wins when it comes to adhesion strength. It is very flexible and has significantly higher adhesion as compared to acrylic tape on most surfaces including fiberboard. Heat Seal adhesives consist of a heat activated thermoplastic film formulated from Polyurethane, Nylon, Polyester, or Vinyl and adheres to virtually any substrate. Heat seal thermoplastic film tapes offer a wide range of possibilities when it comes to laminating, molding, and welding. Heat activated adhesives are custom formulated for use on paper, textiles, and metal foil. Although usually supplied in its neutral color, this product can be tinted to achieve various colors for coding purposes. Heat activated adhesives are generally applied to a substrate via roll coat operation. The coated material is in a non-tacky state until heat is applied, which activates the bonding property. When heat and pressure are applied, the tape is activated, and ultimately provides an extremely high bond. The heat activation point is entirely dependent on the substrate sensitivity and scorch point. What are the Advantages of Heat Activated Tape? Can be designed for rigid or flexible applications. Excellent adhesion. Re-positional Adheres to a wide variety of materials. Excellent for induction curing and seal. Washing machine durable. EPDM extrusion profile bonding for the automotive industry. Electrical appliance industry. Provides excellent performance bonding strength to most rubber, EPDM, PU and PVC based plastic materials. Heat Activated Foam and It’s Possibilities Acrylic foam tapes with a heat-activated adhesive on one side is used to bond to weatherstrip seals, gaskets and other elastomeric materials for automotive and industrial applications. For bonding polypropylene, polyethylene, polyester, nylon, paper, ceramics, wood, fibers & other materials. Capabilities of adhesives include the ability to function in temperatures ranging from 40 degrees C to 140 degrees C or from -30 degrees C to 100 degrees C. Adhesives are available in various grades including inflammable & web grade. Permanent, solvent acrylic adhesive designed for use with heated. The initial tack is either none or very low, allowing most prints to be repositioned before heat activation. This feature makes it a popular choice for mounting delicate prints and/or displays. Once heat-activated, the bond is strong enough to mount to rigid substrates. Selecting the right heat-activated adhesive is more an engineering specification. The Heat-activated adhesive coating allows for an aggressive bonding to hard-to-bond surfaces such as rubber, EPDM, PU and PVC-based plastic materials. And can be made of different carriers; foam, film, and tissue suitable for different types of applications. > > A Guide to Adhesive Tapes: Adhesive Tape Consultant Tape Tape 101 Tape History Tape Glossary PSA Tape Heat Activated Tape Water Activated Tape Non-Adhesive Tapes Adhesives Used For Tape Achieve a Strong Bond Resource Page Foam Tape Structure Transfer Tape Structure Foam Tape Structure Transfer Tape Structure A WIDE RANGE OF INDUSTRY EXPERIENCE Can-Do National Tape. Quote
JHCC Posted April 19, 2021 Author Posted April 19, 2021 Hey, guess what? ANOTHER attempt! Since the Gorilla Glue works just fine and the weak point was the bias tape, I decided to try a piece of the toughest fabric I have: Kevlar! I have a box full of knit Kevlar sleeves (less of a good seller at Quad-State than I’d hoped), so I cut a scrap off the end of one and glued it down. Trim the ends and split the middle: And rip down the middle: I’m letting them cure until tomorrow at least. Reports will be forthcoming. Quote
pnut Posted April 19, 2021 Posted April 19, 2021 6 hours ago, JHCC said: Since the Gorilla Glue works just fine and the weak point was the bias tape, I decided to try a piece of the toughest fabric I have: Kevlar! Have you considered cutting up a cheap nylon tarp to use instead of the kevlar? You'd have to singe the edges but it seems like it would check all the boxes you need for that particular use. Pnut Quote
